Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
removing 914-6 Heat exchangers
I'm mostly a 911 guy but I'm helping a friend remove the 914-6 exchangers and we ran into a decent sized snag. Half the studs have been threaded with plain hex nuts (13mm) and we can't get a socket through the HE to unbolt them. We can get to a few of them by going around but on 4 of them there's almost no access except through the access holes. Is this a typical thing with these HE's? I know on 911's half the studs use M8's (13mm nuts) are removed by going around the HE but it doesn't look like this is possible with the 914-6 HE's.
Also are all of these studs supposed to be put on with barrel nuts?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-04-2003, 07:33 AM
canna change law physics
red-beard's Avatar
No. Some are supposed to be copper hex-nuts.
Yes, they are a *****! I used a universal head on a 1/4 drive. The universal was specific to the nut size.
Biggest problem i ran into was snapping exhaust studs.
When you re-install, use anti seize and new nuts. I am concerned with the use of cad-plated hardware in exhaust applications. It seems the replacement barrel nuts are all cad plated.
James
James
James
Red-beard for President, 2020
Old 11-04-2003, 03:23 PM
Tim Walsh's Avatar
hmm.. ok I guess I'll just have to monkey with it til it's off. Snapping studs isn't a big deal since the heads will be rebuilt anyway but I'd really like to save the HE's's
Note to self: use proper nuts when installing exhaust.
Tim
1973 911T
2005 VW GTI
Old 11-04-2003, 07:33 PM
