ASE Master Tech - 35 yrs
my sixer oil cooler sprung a leak where the pipe-bracket attaches to the housing; what are my sources & choices ??
Take your question over to the 911 BBS, they will know.
it turns out that OTTO's in Venice can repair them and also modify a 911 cooler to match up correctly; Patrick Motorsports makes a conversion setup that uses 2 45-degree AN fittings on a 911 cooler, but i do not have clearance for that solution due to my box-reinforced trailing arms
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
