D7N7MASTER's Avatar
Thumbs down Dual Oil Pressure Sending Unit
Just attempted to change out my "stock" oil pressure sending unit with a "dual" style so that I can connect my new oil pressure guage. But it won't fit. It's to large in diameter to fit thru the engine tin. And even if it did fit, I would have no way to tighten it up. What's up with that??? I'm considereing adding an extension tube to make the installation a lot easier. How is this condition usually addressed???
www.pelicanparts.com/gallery/d7n7master
Old 10-14-2003, 11:23 AM
synthesis's Avatar
You need to run a short hose and mount it remotely, this is a common problem.
AA used to sell a ready made kit for this but they no longer stock it.
You really just need a hose with the correct ends and clamps.
dr
Old 10-14-2003, 11:26 AM
Serge914's Avatar
I bought an extension at Aircooled.net for 20 box.
http://aircooled.net/new-bin/viewproductdetail.php?keyword2=IGD0003&cartid=
They call it a T4 sending unit relocation Kit
Serge
1973 914 2.0 mostly track car
1984 Golf ( Wife car )
1996 Volvo 850 station ( Good family-men car )
Old 10-14-2003, 11:37 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
or a nipple but i don't know where you would get a metric nipple. like he said, you need the hose kit (~ 15 cm hose and adapter).
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 10-14-2003, 11:39 AM
Zeke's Avatar
Pelican has the extension hose. The sender should have had a mounting bracket shipped w/ it.
Old 10-14-2003, 11:50 AM
synthesis's Avatar
the dual sender unit I have came in standard VDO packaging with no bracket.
I was just goint to make one up.
dr
Old 10-14-2003, 11:54 AM
D7N7MASTER's Avatar
Thanks!!! Makes you wonder why PP would sell the sending unit without this info...
Old 10-14-2003, 11:58 AM
SteveStromberg2
Guest
Posts: n/a
Oil Pressure Sender Adapter Kit
VDO-150752 NLA
Old 10-14-2003, 12:55 PM
914 Geek
The bracket, hose, and some adaptor fittings come in the "Adaptor Kit". Call to see if it is really NLA or not.
If so, try a grease gun hose. The hole in the case is 1/4" NPT. Yes, US threads. You'll need adaptors get the other end of the hose to fit the sender, which is also 1/4" NPT. And make sure that you ground the case of the sender.
--DD
Old 10-14-2003, 01:24 PM
JWest's Avatar
I'm pretty sure it's 1/8 NPT (which is about 1/4" in size so it is easily confused).
James
JWest Engineering
Old 10-14-2003, 01:33 PM
914 Geek
DOH!
Yeah, I always say the one and mean the other...
--DD
Old 10-14-2003, 02:04 PM
D7N7MASTER's Avatar
What if I connect the wire from the idiot lite to the oil pres. gage and just don't have a functioning idiot lite?
Old 10-14-2003, 02:48 PM
synthesis's Avatar
I don't think the sender for the light will work with the gauge properly. You need to have the correct VDO sender for oil pressure.
dr
Old 10-14-2003, 02:52 PM
914 Geek
The "idiot light" sender will give you infinite resistance (no connection) when the oil pressure is above ~4 PSI, and zero resistance when the oil pressure is below ~4 PSI. It is a switch.
The sender for the gauge is a variable resistor, and goes from (to pull a number out of the air) 500 ohms when the pressure is zero down to about zero ohms when the pressure is as high as the gauge will read. It varies smoothly throughout this range.
If you hook your gauge up to the light sender, it will read 0 PSI until your oil pressure drops to nothing. Then it will "peg" at max.
--DD
Old 10-14-2003, 03:32 PM
D7N7MASTER's Avatar
Smile
U guyz R the best 914 resourse in the world!!! Well, my world anyway... And I just want to say Thank You for ALL of your suggestions and your feedback with your experience's with my favorite car. I could have made some "dilbert" decisions while restoring our 914 just by thinkin' chevy or vw. You have helped me tremendously.
Old 10-14-2003, 04:51 PM
skline's Avatar
Adn what is wrong with Chevy??????
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-14-2003, 05:08 PM
