Sand Blaster
Got one of the pressurized sand blasters form Harbor Freight. Sure has made cleaning the tough spots easy. We went through 50lb in about 1/2 hr. Bought the first 50lb bag of media at the flaps at 19 dollars. Went today to the local cement supply and they had it in 3 different grades for 5 dollars a 100 lb. This I can live with. Just wanted to pass this on to anyone who may think about buying one. Great Tool.
Randy, (Boogerboys dad) |
I take it you got one of the spot blaster guns instead of a blast cabinet? I got one of the blast cabinets a couple years ago and it was crap. It leaked beads all over the place brand new. Now the rubber gloves are disintegrated (turned into black globs) and the seals and hoses all rotted. So far the only real disappointment from HF, I don't know whether to bother repairing it or toss it in the trash.
I have the portable one as well. Some things are just easier to take out into the middle of the yard and blast away. |
I bought one from Harbor Freifgt 10 years ago , and all the shut off valves got blasted quickly and no longer worked. Wear a respirator that is rated specifically for sand blasting. Pulverized sand dust is nasty and silicosis kills . Later , Pete
A friend has one of those rubber-gloved, leaky-sealed blast cabinets. We used the shop vac technique but found that it pulled too much vacuum (thought the glass was going to suck in). To solve this we drilled a 2" hole (and covered the stock hole) and using PVC plumbing-type connectors screwed on a flange. Some media was still escaping (even though the airflow is inward at this flange - blast velocity was still shooting some media out this opening) so we simply slid on an old motor bike air filter to keep stuff from escaping.
The system works like a charm and the gloves even "inflate" to allow for putting your hands in/out which is nice after a long session and everything's sweaty. Some 'good' media is lost but is a small price to pay to be able to clearly see what you are blasting... "That's my 2 cents worth.....and I expect some change"
Ryan rbroglie@satx.rr.com http://home.satx.rr.com/broglie914/ '72 Summer Yellow 914-4 '74 2.0L Djet powerplant |
I get #2 silica from the local lumber yard. 80# for $4.00
I use blue masking tape to cover most of the lens in my blast hood. When I can't see thru the window, I take a strip of tape off. Only problem is that I have a beach sand driveway. Good thing its a rock drive...
Never enough time to be doing the fun stuff. '70 914-6 2.2 MFI #269 '71 914-4 2.0 '85 911 Carrera |
