update on my project
my dad and i put a 2.2 chrysler turbo in my 72 914. last night i got to test drive it home, on three cylenders. new stuff this week:
brand new set of tires custom exhaust system that has 2 1/4 pipe and one glass pack wired newer electronics into it (took a good 10 - 12 hours) set up the vacuum lines and solenoids. put new fuel lines under the gas tank for the most part the engine fit right in. it just took awhile to get the adapter plate right from the machine shop. i'm only going to be getting between 165 and 180 hp when i get the other cylender working. I'll get more HP when i change the computer (i'll just have to unplug this one run a couple screws to change it) the radiator is mounted right next to the engine. it over heated on the way home from the shop because it needs a new fan, as we discovered last night. |
Sounds like good progress.
Why three cylinders? Bad plug or wire or something? Something easy I hope. Tough to scrounge parts (fan)on a holiday weekend. I had a thought about your shift trouble. If your engine is shaking badly from a cylinder miss this may cause linkage trouble. Check your mounts and watch the engine for excess movement. How soon til you have to go back to school? Are you planning to try to drive the car there? |
I drove my car to see my girlfriend for new years!!! the shifter adjustments helped, and the cylinder that was missing was caused by a fuel injector problem. all fixed! i still don't have second gear, it feels like i am going to have to replace second gear and the synchro. i'm running 195-16-14's and i top out a little too soon... i feel like with the amount of torque in that engine i should have taller tires, or start out in second gear. (which is stillmissing)
| All times are GMT -8. The time now is 09:30 PM. |
