green oil light on when door is open
any ideas on why my green oil light comes on when i open the door? when i push in the door buzzer button it goes off. kind of odd. any tips on how to trouble shoot that?
Old 10-14-2003, 07:53 AM
jnp914's Avatar
ummmm.....top off the door jamb oil tank?
I'm just shooting out ideas here.
Jerry Phillips
'76 912E
Old 10-14-2003, 08:06 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
mis-connected wires, bad grounds?
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 10-14-2003, 08:20 AM
914 Geek
I vote for a mis-connected wire. Possibly something in the seatbelt interlock relay system, if that is still there under the passenger's seat.
--DD
Old 10-14-2003, 08:29 AM
You might take a look under your passenger seat. That's where the door switch and oil light wiring all come together, at the seat belt relay. Here, take a look at this part of the schematic:
F2 & F3 (lower-left) are the door switches. F1 (lower right) is the oil pressure switch. K3 is the oil light and J34 is the relay unit. It's anybody's guess what actually failed but first do a visual check for the obvious, like a loose wire or ground came off. Or maybe the wires got pinched together and shorted. Even the relay could have something shorting inside. If your car was like mine was, I found where water had ponded under there and wires were corroded off the terminals. But at least this is a good place to start looking. Good luck!
Old 10-14-2003, 08:41 AM
skline's Avatar
I like this response. We have to keep a sense of humor about these cars or we really will go crazy.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-14-2003, 09:06 AM
Thanks for the schematic. I will take a look at that this afternoon.
Old 10-14-2003, 09:45 AM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
When ever I have an electrical problem, I change all of the fuses.
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 10-14-2003, 03:37 PM
I looked at the box and the connections. The box and wires are in excellent condition. But, I cant seem to figure out the orientation of the schematic. I was hoping they would appear the same way as they are on the box. the actual box has 3 rows of wire connects. The schematic doesnt seem to show that. The actual box doesnt have the numbers displayed on it. So I assume everything is in order. But who knows :/
Old 10-14-2003, 03:50 PM
The only thing you can go by is the color code on the wires. The oil light should be the green wire with the red stripe. The one I drew an arrow to.
They must have sensed the oil pressure switch to determine if the motor was running for the seat belt interlock. I'd try disconnecting the green/red wires from the relay to isolate that circuit from everything else. That will tell you if the fault is in the relay can.
Old 10-14-2003, 04:44 PM
M. Hendrix's Avatar
If the green oil light comes on when I open the door, I close the green oil light door.
Says so, right in the manual; "Do not open the green oil light door. There are no serviceable part inside the green oil box. If the unit has failed it must be replaced. Please contact the factory if you know of anyone opening the green oil box, or tinkering around in there."
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 10-14-2003, 08:07 PM
How about i just disconnect it. That way being the light will never come on, I will never have an engine problem. Hendrix, feel free to paint your redline on your tach to 10K. If you keep your revs below the redline, you'll be ok
Old 10-14-2003, 08:36 PM
My relay is different than yours Guy. It's a 005 not a 002. Some of the wires are in dif spots, but the oil wire is the same. I will try disconnecting it and see what happens in the morning. Thanks for help and uh comic relief.
Old 10-14-2003, 08:38 PM
M. Hendrix's Avatar
What is a tach?
M
Old 10-14-2003, 08:49 PM
Kenny Powell's Avatar
*914 Poltergeist*
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 10-14-2003, 09:00 PM
The tach is next to that green oil light door
Old 10-14-2003, 09:48 PM
bludden's Avatar
I think y'all may have just helped me in troubleshooting a little gremlin as well....what a great bunch of guys
Brian Ludden
Charlotte NC
'76 914
2k2 VW New Beetle Turbo S
Old 10-15-2003, 07:30 AM
skline's Avatar
As long as everyone is having fun and getting to drive their teeners, that is all that is important.
75 Slantnose V8
72 914 Parts car
Old 10-15-2003, 07:33 AM
Va914's Avatar
My wife thinks I am nutz...She hears me laughing at some of these posts and asks what's so funny......She reads it and then calls me a dork.
I think I am a 914 dork and need help
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 10-15-2003, 09:17 AM
Toast's Avatar
Originally posted by M. Hendrix
What is a tach?
M
It is that round thing with numbers on it that has never seemed to move or work since you first owned the car. It is one of those features that you just figures comes with the car but has no real use, so you just ignore it......Kinda like the Speedometer. If the needle-like device ever starts to move......Pull Over Immediately because something seriously wrong may have just happened to your car!
Oh, and Kerry, I think we all have had a similar experience. Can I here everybody say:
"We are Proud to be 914 Dorks!"
Toast
73 Yellow 2.0
86 Toyota 4X4
Old 10-15-2003, 09:48 AM
