jkeyzer's Avatar
weird clutch problem this morning
I started my 914 this morning and could not shift into 1st gear. It would grind and grind even if I pushed the clutch all the way in and slowly inched into 1st. So I worked the clutch in and out a few times, no good. Then I pushed it into 2nd (it was stiff but didn't grind) and all of a sudden I could shift into 1st with no problem and things were back to normal. Then I drove to work and didn't have any more problems.
Weird, huh??
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 10-28-2003, 09:14 AM
M. Hendrix's Avatar
Well, even on a brand new transaxle, I always sync into 2-3-4 before going from neutral to 1st.
Keep us posted.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 10-28-2003, 09:43 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
One possible cause - clutch disc binding on the pressure plate because it wasn't floating on the mainshaft splines due to insufficient lubrication. Second gear synchro was stiffer, breaking the disc free from the plate. From what I can tell, this happens a lot with the 901 and its clutch.
Old 10-28-2003, 02:05 PM
mike95125's Avatar
Typical smart @ssed comment to follow:
The peddle configuration in all 914s goes Clutch-Break-Gas.
Make sure that you are depressing the far left peddle not the middle.
;P
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 10-28-2003, 03:12 PM
jkeyzer's Avatar
Mike, watch your back!
Jeff Keyzer
Old 10-28-2003, 03:17 PM
skline's Avatar
Hey Mike, I left my stuff in your car on Sunday. Enjoy. Oh, one more thing, it is spelled, pedal.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-28-2003, 03:41 PM
mike95125's Avatar
Scott, I was wondering which spelling weenie (weenee?) would pick up on it first;p And, thanks for the stuff (ambiguity left in on purpose).
Jeff, Tailgunner? hahahaha
-74 BMW R90
Old 10-28-2003, 09:51 PM
914 Geek
And, as long as we're being picky, "break" is something that happens to your car if you fail to push the "brake" pedal in time.
--DD
Old 10-29-2003, 09:54 AM
Unregistered
sammyg2's Avatar
And why do they call it a gas pedal? When fully depressed it allows in a great deal more air that gasoline, maybe we should call it an air pedal?
now where's that lithium..................
Old 10-29-2003, 12:05 PM
Scooter311's Avatar
Velocitator / decelleratrix.
Now where's that c-c-coffee
- "NOW" Magically Delicious -
Old 10-29-2003, 12:50 PM
Toast's Avatar
Maybe its the Pilot bearing?
Its the roller bearing that fits in the center of the flywheel and supports the input shaft of the transmission. Takes about 4 hours to change by yourself! Heres how: Remove tranny, Remove flywheel, punch bearing out, press new one in, reassemble.
Walla!
I would hope after all that that it would definatly fix the problem.
Good Luck!
73 Yellow 2.0
86 Toyota 4X4
Old 10-30-2003, 12:14 PM
Kenny Powell's Avatar
Could be the Dumaflitch Ottamus
Hey pass that......
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 10-30-2003, 01:01 PM
jkeyzer's Avatar
Toast, I thought that might be a possibility too... If it gets worse I'll take off the tranny and figure out what's going on. I was hoping to avoid that until it was time to put in a new engine, but oh well. I'd like to see what condition my clutch is in anyway.. Might as well drop the whole engine while I am at it. Snowball effect...
Jeff Keyzer
Old 10-30-2003, 01:21 PM
philinjax's Avatar
Jeff,
It might be that the shift lever/linkage clamp bolt (the bolt you loosen/tighten when adjusting for proper gear selection) is not sufficently tight. For example, if you were to grab the shift lever and try to move from neutual to first gear while forgeting to push the clutch all the way in or simply slap the lever left and right, just playing around,you might force the shift rod to radially slip just a little. Now, when you push the clutch in, the damned thing won't go in first gear. However, if you then force it in into second (or third, for that matter) and drop the clutch, while moving down the road, the shift linkage radially self readjusts back near proper alignment in order to relieve the tension associated with the misalignment. The next time you select first gear, surprise, surprise, the damned thing works.
Phil
Old 10-30-2003, 01:42 PM
Mine does something similiar. When I shift into first from a dead stop I have to hold in the clutch for about 3 seconds or it will grind. But if I shift into second (first) then it slides right into first no problem. Reverse is the same way..............let us know what you find please.
With car guys I find it best not to nitpik about spelling and grammar.
Old 10-30-2003, 01:51 PM
914 Geek
Jeff, if you want an extra pair of hands for your trans drop, send me an email. If I'm available (definitely happens from time to time!) I'll bop on over with a few tools and a Haynes book...
--DD
Old 10-30-2003, 02:14 PM
jkeyzer's Avatar
John - I think you have a different problem - that is pretty much normal for worn synchros. The difference in my case is that I could not get into 1st at all even if i waited a few seconds - the transmission was not spinning down at all. Not normal at all.
Dave - Thank you for the offer to help. I will send you a note if/when I decide to do it. Recently I have been busy tearing down that 2.0 I scored and learning a lot about engines.
Jeff Keyzer
Old 10-30-2003, 02:35 PM
Toast's Avatar
Originally posted by jkeyzer
Snowball effect...
And then you notice the suspension looks tired, and then...........
73 Yellow 2.0
86 Toyota 4X4
Old 10-30-2003, 03:50 PM
I hate to interject my problem into your thread JKEY, but do you think it could just be the synchro ring or the hub as well. Isnt it just one ring and one hub for first and reverse.
Old 10-31-2003, 10:11 AM
