-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   What cooling tin am I missing? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/134317-what-cooling-tin-am-i-missing.html)
Alfred1 11-04-2003 07:12 AM
I want to buy this 1.8L motor and I told the guy that I want all of the cooling tin but it doesn't look complete to me. Are there some pieces missing?
http://www3.telus.net/public/alpine65/MB1.jpg
http://www3.telus.net/public/alpine65/MB2.jpg
John Rogers 11-04-2003 07:18 AM
Looks like the piece that goes across the front between the engine and firewall is not there and the rear piece that sits on top of the transmission mount flange is also missing.
seventythree 11-04-2003 07:18 AM
Too many to list. And they are all critical.
Dave at Pelican Parts 11-04-2003 08:27 AM
Check here for pictures of the parts you should have:
http://www.pelicanparts.com/914/parts/engine/cylhead_sheet_metal_large.htm
http://www.pelicanparts.com/914/parts/engine/engine_compartment_sheet_metal_large.htm
You need all of those parts. Otherwise you will kill the engine in relatively short order. Also make sure you get the thermostat flaps that go inside the engine tin.
--DD
jkeyzer 11-04-2003 09:00 AM
Are the pieces with the spark plug holes the only difference between 1.7/1.8 and 2.0 tin?
Dave at Pelican Parts 11-04-2003 10:51 AM
Yes, sort of.
There is one piece on each side of the motor that bolts to the side of the sump and to the heat exchangers. The driver's side piece is different between tail-shifter and side-shifter cars. Both are different on the 75-76 cars.
Air conditioned cars have the right-side tin and possibly the front tin hacked up to fit the compressor.
The rear tin piece, the vertical one, is different on the 72s for a pre-heating system that as far as I can tell was never actually hooked up on any 914s.
Those are the only differences I can think of off the top of my head.
--DD
woodman 11-04-2003 04:06 PM
Did any of the 914's have the baffle under the barrels?
Zeke 11-04-2003 04:58 PM
I believe all TypeIV engines had the sheet metal below the cyls. And, IIRC, Jake's video says to make sure you put them back.
SteveStromberg 11-04-2003 07:02 PM
YOU MUST HAVE THE LOWER TIN IN PLACE. You will overheat the motor with out all the Cooling tin in place. Steve
www.ottosvenice.com
SteveStromberg 11-04-2003 07:12 PM
http://forums.pelicanparts.com/uploa...1068001906.jpg.
woodman 11-04-2003 11:20 PM
Thanks Steve & Zeke. I couldn't find mine and thought I didn't have it. But I ended up finding it and now remember pulling it. The only piece of tin I do not have for sure is the tin that goes under the valve cover to the right of the oil filter (#4 in the diagram above, I think).
hardflex 11-05-2003 05:07 AM
#4 fit's directly under the cyls, above the pushrod tubes. did you mean #5?
woodman 11-05-2003 06:52 AM
Yep, I did.
skline 11-05-2003 07:08 AM
#4 is the most important one, there are very few cars that still have #5 still on them. It was more of an exhaust block to disperse heat away from the cylinders at a stop.
And #4 is different for each side. I have all of them but I collected them from different cars. Of all the parts cars I have been through, none of them had all of it.
skline 11-05-2003 07:24 AM
This is from the PET 6 CD, it has the part numbers and as you can see, the numbers are different. It calls the lower ones floor ducts.
http://forums.pelicanparts.com/uploa...1068045832.jpg
http://forums.pelicanparts.com/uploa...1068045847.jpg
http://forums.pelicanparts.com/uploa...1068045860.jpg
Kenny Powell 11-05-2003 07:59 AM
Commonly known as (air guide plates) they are all very important!!!!!
