Banned
Alfred1's Avatar
What cooling tin am I missing?
I want to buy this 1.8L motor and I told the guy that I want all of the cooling tin but it doesn't look complete to me. Are there some pieces missing?
Old 11-04-2003, 07:12 AM
John Rogers's Avatar
Looks like the piece that goes across the front between the engine and firewall is not there and the rear piece that sits on top of the transmission mount flange is also missing.
Old 11-04-2003, 07:18 AM
Too many to list. And they are all critical.
914 Geek
Check here for pictures of the parts you should have:
http://www.pelicanparts.com/914/parts/engine/cylhead_sheet_metal_large.htm
http://www.pelicanparts.com/914/parts/engine/engine_compartment_sheet_metal_large.htm
You need all of those parts. Otherwise you will kill the engine in relatively short order. Also make sure you get the thermostat flaps that go inside the engine tin.
--DD
Old 11-04-2003, 08:27 AM
jkeyzer's Avatar
Are the pieces with the spark plug holes the only difference between 1.7/1.8 and 2.0 tin?
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 11-04-2003, 09:00 AM
914 Geek
Yes, sort of.
There is one piece on each side of the motor that bolts to the side of the sump and to the heat exchangers. The driver's side piece is different between tail-shifter and side-shifter cars. Both are different on the 75-76 cars.
Air conditioned cars have the right-side tin and possibly the front tin hacked up to fit the compressor.
The rear tin piece, the vertical one, is different on the 72s for a pre-heating system that as far as I can tell was never actually hooked up on any 914s.
Those are the only differences I can think of off the top of my head.
--DD
Old 11-04-2003, 10:51 AM
woodman's Avatar
Did any of the 914's have the baffle under the barrels?
'75 1.8 -->1911
Old 11-04-2003, 04:06 PM
Zeke's Avatar
I believe all TypeIV engines had the sheet metal below the cyls. And, IIRC, Jake's video says to make sure you put them back.
Old 11-04-2003, 04:58 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
YOU MUST HAVE THE LOWER TIN IN PLACE. You will overheat the motor with out all the Cooling tin in place. Steve
www.ottosvenice.com
Old 11-04-2003, 07:02 PM
Banned
Old 11-04-2003, 07:12 PM
woodman's Avatar
Thanks Steve & Zeke. I couldn't find mine and thought I didn't have it. But I ended up finding it and now remember pulling it. The only piece of tin I do not have for sure is the tin that goes under the valve cover to the right of the oil filter (#4 in the diagram above, I think).
'75 1.8 -->1911
Old 11-04-2003, 11:20 PM
hardflex's Avatar
#4 fit's directly under the cyls, above the pushrod tubes. did you mean #5?
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 11-05-2003, 05:07 AM
woodman's Avatar
Yep, I did.
'75 1.8 -->1911
Old 11-05-2003, 06:52 AM
skline's Avatar
#4 is the most important one, there are very few cars that still have #5 still on them. It was more of an exhaust block to disperse heat away from the cylinders at a stop.
And #4 is different for each side. I have all of them but I collected them from different cars. Of all the parts cars I have been through, none of them had all of it.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 11-05-2003, 07:08 AM
skline's Avatar
This is from the PET 6 CD, it has the part numbers and as you can see, the numbers are different. It calls the lower ones floor ducts.
75 Slantnose V8
72 914 Parts car
Old 11-05-2003, 07:24 AM
Kenny Powell's Avatar
Commonly known as (air guide plates) they are all very important!!!!!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 11-05-2003, 07:59 AM
