914zim's Avatar
Cat required on a '76 914?
Did my '76 914 come with a cat?
Anyone know for sure?
It doesn't have one now, but maybe a PO took it off.
I'm trying to decide if I should put one on before I go in for an emissions test. I'm not to that point yet, but I'm trying to think ahead.
Thanks!
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-30-2003, 09:02 AM
914 Geek
Can you find the emissions equipment sticker in the engine bay? It is probably of the left side wall. It should say something about what equipment was delivered on the car.
If it's a CA-spec car, it should have a cat.
--DD
Old 12-30-2003, 09:14 AM
914zim's Avatar
Great, I'll check for it Thanks Dave.
What about this air pump?
My car has an air pump pulley, but now pump.
Is this an emissions part?
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-30-2003, 09:21 AM
914 Geek
Yup. I can never remember which cars had the pump and which the cat, and I'm not sure any had both. Frankly, I haven't paid that much attention to the later smog equipment. I looked into it and decided I didn't like any of it, so I haven't spent much effort thinking about any of it because I was not going to own a 75-76 car with it.
Best thing to do, though, is check with your local smog people to see what you, as a current resident of your current state, are supposed to have. Heck, you may not even need fuel injection on a car that old in WI. (Not sure, never dealt with their smog laws.)
--DD
Old 12-30-2003, 09:33 AM
Amark's Avatar
If it came with a Cat there should be a big yellow "CATALYST" sticker on the drivers door jamb.
Mark
73 2.0
Old 12-30-2003, 09:42 AM
914zim's Avatar
Thanks guys!
I'll check tonight.
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-30-2003, 10:02 AM
Ron Meier's Avatar
Your instrument panel will have an egr light between the guages.
Your speedo cable will be two piece - one long from the tranny to the egr counter underneath the foam footrest on the pass side and a short one from the egr counter to the speedo.
etc etc etc
If you need an assembly w/ cat I know someone who may have it (if he hasn't thrown it away).
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 12-30-2003, 10:57 AM
bowlsby's Avatar
Miles Julihns 76 car was a 49 state car...later imported to CA. It had an air pump but no cat. He later needed to put a cat on it so it would pass CA emissions testing.
Old 12-30-2003, 11:15 AM
914zim's Avatar
I think I'll just put a cat on, skip the air pump and see if I pass.
I only need to pass once because I will get collectors plates for it and then it will be exempt after that.
Thanks fellas!
Andy....
'76 914 Black/Black
VIN:4762900785
Old 12-30-2003, 11:47 AM
Ornery Bastard
Thanks fellas!
Andy....
Actually, if the thing is in proper tune, it might not need a cat to pass inspection.
My '76 has no cat, never did, and that's a good thing. The extra loop-arounds necessary to add a cat create a lot of backpressure and rob a good bit of power.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 12-30-2003, 06:50 PM
914zim's Avatar
I checked my car last night and it does has stickers in the engine compartment and on the driver's side door. I'll put a cat on for the inspection and who knows what it'll happen afterwards.
Thanks for all the input guys!
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-31-2003, 04:51 AM
RETIRED
Joe Bob's Avatar
Get the specs needed to pass first.....then run it so that it's good and warm. Get a pretest at a wrench that has a good analyzer. Adjust as neccessary and then go to the State run facility for the official test.
2012 ML350 3.0 Turbo Diesel
Old 12-31-2003, 07:45 AM
914zim's Avatar
Good idea!
Now I just need to get it running!!
'76 914 Black/Black
VIN:4762900785
Old 12-31-2003, 11:47 AM
