914zim's Avatar
Muffler(s) recommendations?
Fellas:
Well, it looks like I will need a new muffler and also will need to add a cat to my 76 914.
Some of the mufflers I'm seeing on the net or 914s don't look like they'd fit my car.
Can you guys tell me what you think of your mufflers and where did you buy it and
how much did it cost?
I am assuming I will need to add a cat to my car in order to pass emissions here in WI.
Any thoughts or comments are appreciated.
Thanks!
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-27-2003, 05:22 PM
Jim Smolka's Avatar
It is possible to get a '76 2.0 to pass emissions test w/o a cat. May require adj the valves a little loose.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 12-27-2003, 05:46 PM
914 Geek
Depends on the exact standards and tests used. For instance, if they have a "visual check" you're hosed without the cat.
The only cat-equipped system I know of for a 914-4 is the original 75-76 exhaust. The header pipes are separate from the heat exchangers, which feed into a primary muffler that in turn goes to the cat and then to the secondary muffler. (I think I've got that order correct there!) Not a cheap setup to buy if you've got the earlier-style setup on it. If so, then I suggest trying to pass with what you have.
--DD
Old 12-27-2003, 07:16 PM
Biggy72's Avatar
what if you just got a cat off another car and welded the guts onto the outside of the tubing somewhere where it'd fit and then doing the valves? I've got some friends that gutted their cats on different cars, if they didn't just cut them completely off.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 12-27-2003, 07:32 PM
DuckRyder's Avatar
Send a message via AIM to DuckRyder
Were not the only cat equipped cars California cars?
My 49 state 75 never had a cat.
Old 12-28-2003, 04:55 AM
boogerboy72's Avatar
Send a message via AIM to boogerboy72
i was thinking along the same lines of duck ryder. I also though the ca models were the only ones with cats.
Musha ring du ma do dum a da
73 1.7 (mine) possible a 2056 from Raby a LONG ways down the road.
74 2.0 (dads)
My lug nuts have more torque than your civic does.
Old 12-28-2003, 05:45 AM
muffler w/cat
go to exhaust section of Pelican auto parts and view the Boursch muffler with cat muffler is $215 (I think) and cat an additional $37 These are made to fit your car (so says the site)
Old 12-28-2003, 08:24 AM
914zim's Avatar
Thanks fellas....
Isn't the PP $37 for the bypass pipe, not the cat?
I am planning on buying the Bursh from PP, but not sure where to get the correct cat from.
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-28-2003, 12:00 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
I have this one twin Cats Twin mufflers.$150 Steve
Old 12-28-2003, 12:38 PM
914zim's Avatar
Would that fit my '76 2.0L 914?
I like the twin look!
Thanks,
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-28-2003, 03:06 PM
Banned
Its bolt on a 75 that has had the bumpers changed, yes it will fit your car. Steve
Old 12-28-2003, 05:31 PM
914zim's Avatar
muffler
Steve:
I measured 26" from center to center.
Does your muffler match this?
If it does and you tell me it's in good condition,
I'll take it for $150. Have any idea what shipping would be to 53146? (WI)
'76 914 Black/Black
VIN:4762900785
Old 12-28-2003, 05:55 PM
914 Geek
I suggest checking with your local DOT/DEQ/whomever is in charge of smog inspections. Most 75-76 914s did not have catalysts, and I wouldn't think that one would be needed in WI.
--DD
Old 12-29-2003, 08:46 AM
914zim's Avatar
Good point Dave.
I'll do a little digging.
Thanks!
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-29-2003, 09:39 AM
914zim's Avatar
Steve:
Can you get back to me on this?
I sent you a PM.
Thanks,
Andy...
'76 914 Black/Black
VIN:4762900785
Old 12-30-2003, 01:03 PM
