Stuck Lifter
My two liter rebuild went pretty smoothly, but I have had two issues after installing and driving the motor. The first was a loud knocking noise fromt he passenger side of the motor and the second was a loss of oil pressure after the engine warmed up. I have now removed the motor and taken the heads and cylinders off to find that the intake lifter on the #3 piston will not come out of its bore. I am betting that this is the source of my knock, but am wondering if it might also be contributing to my loss of oil pressure... any thoughts?
Monty
Old 02-02-2004, 11:15 AM
Bad lifter= flattening cam= severe amounts of foreign debris from the extreme wear.
As the parts wear all the debris goes through the oil pump and bearings- double check everything before it goes back together, especially the pump.
This all equals out to the fact that you have just become a statistic.
Take it apart- start all over . Guaranteed. No way out of it.
The lifter has mushroomed and the head will not come through the bore now.
Another one bites the dust.
what lifters did you use?
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 02-02-2004, 11:30 AM
Acox914's Avatar
Send a message via AIM to Acox914
ouch
-Aaron
"60% of the time, it works every time"
Old 02-02-2004, 03:14 PM
Thanks Jake for the quick response, I will check on the lifter brand as it was quite some time ago when I bought the parts. The motor has less than 30 mins of run time on it.. and the lifter and pushrod were new and the cam was reground... the other side had no trouble. What you say makes good sense though.. oh well that is why its a project car, not yet a daily driver..
Monty
Old 02-02-2004, 03:33 PM
yep, with 30 min of run time I'll almost betcha thats the culprit..
You are not alone it happens to the best of us. How did you break in the cam???
Jake Raby
Old 02-02-2004, 05:47 PM
Jake,
I did not do anything to break in the cam. This was not mentioned in any of my reference material, I would appreciate any guidance you could give me on this, before the motor goes back together...
Monty
Old 02-03-2004, 08:06 AM
914 Geek
Running the engine with no load for 20 minutes at 2000-2500 RPM is the "traditional" cam break-in. Usually done by propping the throttle valve open a little ways (not with anything that could fall in!!) and just letting it go.
I think I remember Jake using a slightly different procedure--different time and RPM, possibly?
--DD
Old 02-03-2004, 08:12 AM
Member w/ Title Problems
Jason Porter's Avatar
Did you ever find out which brand of lifter it was you ran?
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 02-03-2004, 11:11 AM
914 Geek
Damn, that's confusing having the same avatar, Jason! I'm gonna have to ditch my avatar, I think....
--DD
Old 02-03-2004, 11:32 AM
would I be out of line with some nice boobies on my avatar?
Old 02-03-2004, 11:43 AM
Jake Raby
Old 02-03-2004, 12:26 PM
Thats without a doubt the issue...
I'll make a detailed post later.
Jake Raby
Old 02-03-2004, 12:27 PM
Please tell us what kind of lifters you used.
PS - Jake, what would be a good time for me to call you directly?
Old 02-03-2004, 01:00 PM
Joe Sharp's Avatar
Gosh, I hate this. I was thinking of going out to the shop and gluing together my cases. Euro 2056 w/ WEB 107i cam and lifters and matched ports. How many more people are not doing thier engins because of lifter paranoia?
Joe
http://www.clubnarp.com/
My mechanical ability seems to be directly related to my ability to withstand pain.
He who plays with the most toys wins.
Old 02-03-2004, 06:00 PM
I bought the lifters in 1991 from Engine Builder's Supply (they also did the cam grind, and JE forged Pistons). I found the receipt but it does not list the brand nor do I have the box. I am sorry to not be able to give more info than this... I still have not had time to crack the case open, but should manage that this weekend.
Monty
Old 02-05-2004, 10:40 AM
That sucks. Good luck man.
PS - You know who to call if you need anything, right?!(wink-wink)
Old 02-05-2004, 11:23 AM
Yes, Jason I am definitely going to replace that lifter... need a gasket set, may replace all the lifters, also need an oil temp sender and did not seem to see it on the online catalaog??
MOnty
Old 02-05-2004, 12:11 PM
Give us a call at 888-280-7799, and dial ext 280 for sales. Any of those guys can take care of you with a quickness.
Old 02-05-2004, 12:28 PM
