-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Why do all of the four-cylinder 914s use the same camshaft? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/147004-why-do-all-four-cylinder-914s-use-same-camshaft.html)
Alfred1 02-03-2004 04:35 PM
You'd think that each of the different engine designs would need its own unique cam ...
philinjax 02-03-2004 04:59 PM
There are at least three distinctly different stock type 4 engine cams. These cams are identified by casting markings.
Check out "Type 4 Secrets" for the cam info.
Phil
Jim Smolka 02-03-2004 05:00 PM
Though some are different, D-Jet Cams on 1.7 and 2.0's were mild since the MPS does not pulses from a big cam.
SteveStromberg 02-03-2004 05:06 PM
The cams are ID by a bump on the casting. I will see if I have a photo to post. Steve
