-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   where is engine serial number? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/150444-where-engine-serial-number.html)
Jappe914 02-25-2004 10:37 AM
I have looked everywhere and there are no numbers on the block.
Block is completely washed...
My project
lapuwali 02-25-2004 11:00 AM
Right hand side, near the bellhousing. If you look down while standing on the passenger side of the car, the number is almost directly beneath you, perhaps a bit in towards the center and towards the rear.
D7N7MASTER 02-25-2004 12:21 PM
Look down at the oil filler tube. Now look just in front of it towards the front of the car. BUT-not all cases have s/n's so...
Jake Raby 02-25-2004 12:48 PM
If it was from a 912E the case will not have a serial number... Some other 76 914s also do not have any numbers on the case, just the blower housing..
Jappe914 02-26-2004 01:25 AM
It has no number at oil filler tube. It is -73 1,7 but it has similar heads as T-2. Should 914 engine intakemanifold been bolted with 3 bolts or 4 like T-2 / 411/412. I have seen many heads with that 3 bolt intake
Jake Raby 02-26-2004 06:49 AM
3 bolt intakes are for 2.0 914 heads only. all others had 4 bolts.
gcd914dab 05-19-2007 11:21 AM
what engine is this
one of my blocks has this stamped number on it...CJ081941..it has dual port heads...what is it???...thank you
Dave at Pelican Parts 05-19-2007 10:38 PM
All Type IV engines have dual-port heads...
According to this website, your CJ case is from a Euro-spec Bus, and would have been 2.0 liters originally, and making 70 HP.
--DD
