Steering wheel upgrade problem
OK heres the deal: I have a 72 914 (built 10/71) I bought a used dino steering wheel and adapter form an auction site. After spending hours to restore the spokes and hand stitch the leather wrap, the adapter does not fit. The splines are the right size, but the adapter bottoms out on the column about 1/2 inch too soon. I noticed on the original wheel for my car, the splines are deeper in the steering wheel hub. I guess I am not sure what adapter to buy now. The previous owner of the Dino wheel said it was from a 74. I wonder if my car still has the 70-71 style steering column, which is hard to find an adapter for.
thanks
Mark
72 914 5.0L
Old 02-29-2004, 06:43 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
What is the bolt pattern on the wheel. Steve
Old 02-29-2004, 08:29 AM
the pattern is 5 bolt
Old 02-29-2004, 09:47 AM
Banned
5 By? 100mm ?
Old 02-29-2004, 12:23 PM
tat2dphreak's Avatar
I'm guessing, but a grant hub would probably do the trick... measure the wheel, and then go to a FLAPS and measure the hub there... most pepboys sell Grant.... they may not have the right one, but you will know if the bolt pattern is the same.
'72, now with a living, breathing 2056...
Old 02-29-2004, 12:41 PM
5X 3in diam. so it must be 75mm
Old 02-29-2004, 12:42 PM
I guess I am wondering if my coulmn is a 71 and earlier style or a 72 and later style. Everything else on the car trns out to be a pre 72 style
Old 02-29-2004, 12:44 PM
Acox914's Avatar
Send a message via AIM to Acox914
cut the adapter down .5 inch. i sold someone the same style adapter, and this is what they had to do. it apparently worked great!
-Aaron
"60% of the time, it works every time"
Old 02-29-2004, 04:12 PM
The adapter needs to move .78 inch. If I cut that much off I will only have 5mm of spline left on my adapter.
Old 03-01-2004, 01:01 AM
Amark's Avatar
This might help you.
http://www.914club.com/bbs2/index.php?act=ST&f=2&t=2032&hl=dino%20wheel&st=0
Mark
73 2.0
Old 03-01-2004, 12:10 PM
