DTM in a 914!
http://www.shoptalkforums.com/viewtopic.php?t=65728
Thats a post over on my forum with alot of pics...
Long story short I had a blast with my little low power 912E!
even more than that it was the weekend of proving for the DTM at the track!
This car previously had a FAT 11 Blade 911 fan and shroud..... It now runs 50-75 degrees COOLER all the time and NO OTHER CHANGES WERE MADE TO THE ENGINE TILL AFTER IT WAS RAN FOR A COMPARISON!
So now, the DTM is proven in every single way possible... Dyno, Street and Road Track!
Look for a post from the car owner explaining what he saw in the cockpit- and felt in the seat of his pants!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 02-23-2004, 08:32 PM
howardchen327's Avatar
Nice!
Jake do you have a DTM shroud kit for 914?
I've look'n for it on your site...but only the 912 & 356 are listed
Thx
1971 914 with GA2.0...My first car! Love the sound, Love the rough ride...Just 914, THAT'S ALL!
Old 02-23-2004, 10:32 PM
This was the first DTM to go into a 914. The shroud is the same as all the rest of the DTMs... we never tried to make it fit into a 914 before. In a stock car the rain tray would have to go and the decklid be slightly trimmed for the hatch to shut fully.
Jake Raby
Old 02-24-2004, 06:34 AM
Anyone know what a "DTM" is, other than the German touring car racing series, that is. . .
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 02-24-2004, 01:47 PM
Banned
Alfred1's Avatar
Click here .
Old 02-24-2004, 02:12 PM
Wut DTM for 914
Spec of my car:
1973 GA 2.0 MOTOR, D-JET
Jake, if I want to put a DTM kit in my car (without carb now...maybe in the future) which stage do I need? I'm looking for a kit that requires minimum DIY (BOLT IT ON).
Thx!
Old 02-25-2004, 02:42 AM
oil cooler
Do I must to instal one with DTM? where can I mount them...i don't want to cut a hole anywhere on the car
Old 02-25-2004, 02:44 AM
The DTM is not compatible with D or L Jet.... Nust use individual runner EFI or carbs...
Reason # 4,345,581 to throw the stock EFI system out the window at 120 MPH!
Jake Raby
Old 02-25-2004, 07:52 AM
914 Geek
Not only that, but you have to cut the rear deck lid for the DTM to fit (if I read the STF post correctly). Or have a removable one, like the car that has the DTM in it currently.
At least at this point, it sounds like a race-car-only thing for a 914.
--DD
Old 02-25-2004, 08:43 AM
It would fit with slight cutting of the decklids sealing lip....
I can change the mold 10% up top and not change the cooling at all. We are doing that now.
Jake Raby
Old 02-25-2004, 12:07 PM
boogerboy72's Avatar
Send a message via AIM to boogerboy72
So will it evenventually be a 100% bolt on item? If so, Where can i find pricing on it?
Musha ring du ma do dum a da
73 1.7 (mine) possible a 2056 from Raby a LONG ways down the road.
74 2.0 (dads)
My lug nuts have more torque than your civic does.
Old 02-25-2004, 04:51 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
For a street car the nice thing about the stock cooling system, is that if the belt breaks it will run till the battery goes flat. Steve
Old 02-25-2004, 05:37 PM
Steve's point is well taken. I've spun the belt off my T4 several times, or broken one, and it's nice to not worry about cooking the motor as a result.
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 02-25-2004, 06:40 PM
That is a nicer point of the stock system... But u\its weight and bulkiness is not. The DTM is a one piece design and slides right over the engine. It weighs 9 pounds!
The stock 914 alternator is a less than fun experience to replace and it uses an external regulator. The DTM uses beetle parts and a brand new alternator with internal regulator cost 129.00. It can be removed and replaced in the car in less than 20 minutes with two wrenchs (11 and 13mm)
www.massivetype4.com is the website addy for the DTM.
Thrown belts are not a common occurance. Since the DTM is built on top of a TIV engine longblock the alternator stand is set up and the deflection from the lead to trail sides of the belt are aligned infinately.
Mark takes his engine to 8,000 RPM and the belt stays on.
Jake Raby
Old 02-25-2004, 09:06 PM
Sounds great, but will it be a direct bolt on? Im really not interested in cutting up the rain tray/rear deck lid.
74 2.0 (dads)
Old 02-26-2004, 07:43 AM
And what about those lucky enough to have operative stock FI? (knock on wood!)
Old 03-08-2004, 06:00 PM
914 Geek
In that case, you keep the stock system. Jake is not a fan (perhaps that's way too mild a way of putting it) of the stock FI system.
--DD
Old 03-09-2004, 09:10 AM
I am not a slave to "originality," but as long as it works I leave it as is then "upgrade" as needed. Kind of the rolling rebuild always in progress. Besides wife is still angry at MG and a Mini project taking over garage . . .
Old 03-09-2004, 10:49 AM
