Ignition Coil
This is going to sound like a "dumb" question. How is the "coil" wired. It's a Bosch Blue coil with a positive, a negetive and a distributor connection. Seem to be confused.
Old 03-23-2004, 08:16 AM
Positive goes to your +12v via ignition switch, negative goes to your points and tach, the high-voltage goes to the dist. cap.
Old 03-23-2004, 08:46 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
black/purple wire is to tach and is connected to - coil terminal
check wiring schematics on this site to see connections
http://www.pelicanparts.com/914/parts/Electrical/914_electric_74E.jpg
coil is "N" in tracks about 85-87
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 03-23-2004, 08:58 AM
Banned
Alfred1's Avatar
Apparently, there are a few different types of Bosch blue coils. This thread http://www.shoptalkforums.com/viewtopic.php?t=62438 can help you determine which is right for your application (e.g., if you are using a Pertronix or Compufire unit).
Old 03-23-2004, 09:52 AM
