grind weld build
sean_V8_914's Avatar
Question Piston clearance
what is typical for piston to cylinder clearances in an air cooled T-4?
if the piston measures 94mm, what should the bore measure?
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 03-24-2004, 10:05 AM
Banned
Alfred1's Avatar
For the 2.0L motor, the 914 Technical Specifications booklet says that the cylinder/piston play for new parts is 0.02 - 0.05 and 0.20 for wear limits (I believe those are mm values).
For 96 mm, KB hypereutectic pistons, Jake likes ".002 measured @ .500 above the skirt" (values in inches, I believe).
Old 03-24-2004, 10:30 AM
grind weld build
thanks! That is similar to what I would expect when building a Chevy. I thought an air cooled engine might want more clearance
73 Orange, CS #601
Trek 6500+
Sean M!
Old 03-24-2004, 12:02 PM
With forged piston, yes, they need more clearance, like ".0035. Keith Black's don't expand, so you can run them tighter. Though for comparison, we've run our Nickies as tight as ".0015 w/ JEs, since they expand at the same rate.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Charles Navarro
President, LN Engineering and Bilt Racing Service
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-24-2004, 02:24 PM
