I have a 1972 914-4 and I am getting no fuel to the carbs. the car has set for 1 1/2 years. I bought it 2 weeks ago. I have got it to turn over, and with some starting fluid, I can get the motor to "fire", but not start. Any hints? Paul
Do one thing, Do it well, Then move on |
914 Geek
Is the fuel pump running?
Is the tank full of dirt and crud? --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
No fuel to carbs
Emptied tank, clean
Changed fuel filter I can hear pump running when key is in acc. position Paul
You can hear the pump running, but is anything actually coming out of it? Put one end of the hose in a bucket and turn the key.
If you don't get fuel that way, there's a blockage in the tank or a blocked hose. If you do get fuel this way, I'd venture you have stuck needle valves. Probably gunked up and full of varnish. If so, get a carb rebuild kit. They're not expensive, and include new needle valves. |
Hoses hooked up correctly after you cleaned the tank......?
-- Dave '73 914, 2056 GT/SC done! '69 Lotus Europa S2 - under resto. pics at http://www.syer.net |
