mikester's Avatar
Send a message via AIM to mikester
taco plate seal
I need to replace the seal on the plate that holds the oil temp sending unit.
Anyone know what it is called and where I can get it?
Didn't see it in the catalogue...
thanks
-The Mikester
I heart Boobies
Old 03-31-2004, 07:47 AM
synthesis's Avatar
I got one not too long ago, it was a big red o-ring. Don't know the part number but most places should have it.
dr
Old 03-31-2004, 08:14 AM
Unregistered
sammyg2's Avatar
Are you looking for the gaskets for the sump plate? If so pelican has em at http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_oilsys_pg3.htm#item15
Old 03-31-2004, 09:22 AM
914 Geek
Nope, that's not the same gasket. This is, as described, a big red O-ring. I don't thikn it's listed in the catalog, but it is available. Call 888-280-7799 and ask our friendly Sales staff.
There is also a paper gasket and a couple of crush washers. I don't know if the gasket is still available (at one point it was not). It goes between the lower "cover" plate and the plate that the sender actually screws into. The crush washers, of course, go under the bolt-heads. They are prety standard parts.
--DD
Old 03-31-2004, 09:33 AM
Member w/ Title Problems
Jason Porter's Avatar
By my calculations, the part number for your gasket is #021 101 269A. That's the gasket for plate #021 101 267. And yes, you should call
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 04-01-2004, 10:05 AM
