MXMARK's Avatar
Too low or not? and Sorry swapmeet!!
What do you think? Should I raise it of not? Sorry to all for getting out of control at Glenns Swap. on 04/04/2004
I was a little hard on the transmission, and on the motor (rpm 7k) today. Sorry. And sorry to my Baby 914. Sorry again and Thanks Mark.
1985 Targa Carrera
1972 914 2.5L four, side shift
1987 944
2005 Husqvarna CR125
1980 YZ125G
Old 04-04-2004, 10:47 AM
Biggy72's Avatar
too low? what's that? it looks good, if it drives nice and doesn't ride bad then leave it alone.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 04-04-2004, 11:09 AM
MXMARK's Avatar
Biggy72, Thanks Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 04-04-2004, 11:14 AM
SGB SGB is offline
SGB's Avatar
Loooks puuurfect.
-Scott
My gallery page
Old 04-04-2004, 08:32 PM
914 914 is offline
914's Avatar
nice looking 914
What Did You Do ???? Open The Teener Up....
Old 04-04-2004, 09:17 PM
synthesis's Avatar
too high in front, too low in back. Looks like your rake is in the wrong direction.
you want to set your front a-arms just less that parallel to the road, biased toward the longer adjustment. Then set the rear to have a slight rake forward.
This is a baseline. Adjust for handling traits depending on course or track.
dr
Old 04-05-2004, 04:46 AM
lmcchesney's Avatar
Mark, have you measured your conner weights?
In the picture, it looks as if your front is to high compared to the ride height of the rear.
L. McChesney
Old 04-05-2004, 07:23 AM
Va914's Avatar
Sorry for the hi-jack
I like the idea of setting the ride hight based on the A-arm position. So the A-arm should be JUST on low side of parallel, correct?
Could you measure the angle of the A-arms to compare sides to insure they are the same? I have a hard time measuring from the ground up to the same point on both sides to verify the sides are the same height. Seems like the angles would be easier to measure and compare
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 04-05-2004, 09:28 AM
MXMARK's Avatar
Thanks guys for all of you help. About 3 years ago I put 911S koni's and S calipers on a Carrera front set up. I set the toe by tape messure and left the tops the way they were. I also put yellow koni's all the way around with adjustable rear preload collars and nuts. The rear is a little higher then the front, maybe 1/2 inch. I did raise it before this picture. Next will be drop the front more,corner balance,rake or caster and adjust to track.Thanks again I will get to adjusting.
And yes, I did open up the teener in front of the swapmeet. I was giving Acox914 a ride. Thanks Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 04-05-2004, 10:12 AM
