-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   burned up wires while putting in fog switch (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1585-burned-up-wires-while-putting-fog-switch.html)
billy petrow 03-22-2000 03:41 PM
What do I have to do to correct this problem?I put on the wires that were left there by the factory, put on the lights and pulled the fog switch and smoke like u couldn't believe came out of the dash. Need as much info as possible. PLEASE HELP!
mejulihn 03-22-2000 04:33 PM
Just a guess here, but it sounds like you've got things wired incorrectly. The switch on the dash should be wired to activate a relay (which is itself a type of heavy-duty switch). Your fog lamps then pull their amps thru the relay and not the dash switch. If it is wired wrong, you can pull more amps thru the switch on the dash than it is designed for, causing it to fry.
Jim Smolka 03-22-2000 06:56 PM
Break out the Haynes manual...
I was able to install mine just fine in a '75.
Check the wattage of the lights you are installing.
A couple of tricks I would try...
1st. Disconnect the lights.
2nd Disconnect the fog relay
3rd Disconnect the switch
Check the wiring to the haynes manual.
Check for shorts...
Fix as needed.
Connect loads in reverse as seen above.
IMHO
Good Luck....
Smoke Daddy
