-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Adding Foglights (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/158923-adding-foglights.html)
peter carroll 04-17-2004 06:08 PM
Adding Foglights
Found some fogs in the junkyard. Found a switch in another junkyard. Lights work off the car. Connected switch and lights to car.(they don't come on) Do I need to do something else? Thanks, Pete
415pb 04-17-2004 10:17 PM
Mine didn't work either. I turned the switch on and checked to see if I was getting power to the lights and I wasn't. I replaced the relay and it worked fine after that.
peter carroll 04-18-2004 07:20 PM
Would a relay exist if the car never had fogs to begin with? Thanks
415pb 04-18-2004 07:59 PM
Peter If I recall correctly, I had the relay but didn't have foglights. The relay was bad when I finally installed the lights, so I changed it. I will take a pic of where my relay is.
415pb 04-18-2004 08:19 PM
Peter, there should be a relay with a red wire and some white wires going to it. This is the one. If you look at your foglight wiring up front, I believe you have ground and a white wire with I think a blue stripe. This wire will be the same running to the relay socket. Hope this helps.
http://forums.pelicanparts.com/uploa...1082344748.jpg
Dave at Pelican Parts 04-19-2004 06:57 AM
Don't trust the positions of the relays on that fuse panel. Check the wire colors--the relays can be installed in any-old-place, but the wire colors have to match.
--DD
peter carroll 04-21-2004 06:56 PM
Thanks for all of your efforts. Pete
