Adding Foglights
Found some fogs in the junkyard. Found a switch in another junkyard. Lights work off the car. Connected switch and lights to car.(they don't come on) Do I need to do something else? Thanks, Pete
Old 04-17-2004, 06:08 PM
415pb's Avatar
Mine didn't work either. I turned the switch on and checked to see if I was getting power to the lights and I wasn't. I replaced the relay and it worked fine after that.
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 04-17-2004, 10:17 PM
Would a relay exist if the car never had fogs to begin with? Thanks
Old 04-18-2004, 07:20 PM
415pb's Avatar
Peter If I recall correctly, I had the relay but didn't have foglights. The relay was bad when I finally installed the lights, so I changed it. I will take a pic of where my relay is.
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 04-18-2004, 07:59 PM
415pb's Avatar
Peter, there should be a relay with a red wire and some white wires going to it. This is the one. If you look at your foglight wiring up front, I believe you have ground and a white wire with I think a blue stripe. This wire will be the same running to the relay socket. Hope this helps.
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 04-18-2004, 08:19 PM
914 Geek
Don't trust the positions of the relays on that fuse panel. Check the wire colors--the relays can be installed in any-old-place, but the wire colors have to match.
--DD
Old 04-19-2004, 06:57 AM
Thanks for all of your efforts. Pete
Old 04-21-2004, 06:56 PM
