LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
SGB SGB is offline
SGB's Avatar
Post Impending rebuild
Hi-
Looks like the winter project will be a (at least top-end) rebuild of my two liter. It has been many many years since I did last one, and I began to wonder what items (parts) I will need and could I go ahead a start collecting 'em. I expect one slightly burned exhaust valve to be replaced. Anybody got a handy list of basixc rebuild parts needed? Y'know- gasket sets, seals, PR tube seals, etc. I'll probably do my 1st and 2nd gear synchros too, so I gotta figure out what is needed for that too. I realize that a lot of things just aren't knowable untill the engine is apart, but anything to help me get my act together before I drop the motor would be really helpful....
Suggestions?
-Scott
My gallery page
Old 05-21-2004, 08:29 AM
Crankshaft 71mm Std Polished
Con Rods 2.0 Rebushed (4)
039 198 075 2.0 Ltr. EURO Pistons and Cylinders
CR 8 to 1 German
021 198 481 A Std. - Main Bearings German
111 101 123 Main Bearing Dowel Pins (5)
039 105 701 2.0 Ltr. Std. Rod Bearings- German
113 105 427 Rod Nuts (8)
021 105 431 A Piston Pin Bushing (4)
039 109 611 L Exhuast Valve TRW Sodium Filled (4)
039 109 601 G Intake Valve TRW (4)
113 109 651 A Valve Keepers (16)
110 0530 120 Valve Spring (8)
021 109 021 M Camshaft
021 109 309 G Lifter (8)
021 109 301 A Pushrods (8)
021 109 335 C Pushrod Tubes (8)
901 105 370 02 Valve Adjusting Screws (8)
999 034 005 00 Valve Adjusting Nuts (8)
111 105 223 Distributor Drive Gear
021 105 209 A Crankshaft Timing Gear
111 105 213 Crankshaft Timing Gear Key
113 101 157 C Cam Bore Plug
021 117 021 B Oil Cooler
021 115 107 AK Oil Pump
021 919 081 B Oil Pressure Switch
021 115 351 A Oil Filter Mahle (2)
039 198 009 Complete Engine Gasket Set 2.0 73-76
021 105 245 C Flywheel Seal
021 105 247 A Pulley Seal
111 105 313 A Crankshaft Pilot Bearing
022 105 273 A Flywheel
N 014 336 1 Flywheel Crank Bolts (5)
901 116 001 HP H D Clutch Kit-
09004-021035255B Spark Plug wire set
113 905 207 C Distributor Cap
055 905 225 B Ignition Rotor
311 905 295 C Ignition Condenser
9-232-081-044 Ignition Contact Set
W-7-CC Sparkplugs (4)
039 199 231 Engine Mount (2)
914 375 025 00 Transmission Mount (2)
914 424 224 03 Shift Rod Bushing Front 73-76
914 424 224 02 Shift Rod Bushing Rear 73-76
911 424 024 98 Shift Coupler Bushing
901 424 229 00 Shift Coupler Set Screw (3)
Old 05-21-2004, 09:06 AM
tat2dphreak's Avatar
wow, great list man!
'72, now with a living, breathing 2056...
Old 05-21-2004, 09:52 AM
SGB SGB is offline
SGB's Avatar
Talking thx
well, there ya go. THANK YOU sunsetter
-Scott
My gallery page
Old 05-21-2004, 10:45 AM
lmcchesney's Avatar
Nice job Sunset. BTDT situation, Yes?
Another is to check in with Jake's kits on Aircooled.net. He also has a video to walk you through and from others, is available to help if needed. I believe, Jason here at PP also will make himself available to guide you. Of course and last resort, tounge in cheek, the forums would be glad to help. Like, cram that two by four under the engine and get your 300# coworker to lean on the end.
Old 05-21-2004, 12:39 PM
Member w/ Title Problems
Jason Porter's Avatar
I'll be glad to help you with either a stock or super-sized rebuild
Jason Porter - 888-280-7799 ext 233 - jason@pelicanparts.com
1989 Chevy Silverado 3500 - 454TBI, 4x4, 8 gallons/mile
Old 05-21-2004, 12:50 PM
