skline's Avatar
Radiator Install
Here is a picture of the radiator in the car. It is not installed yet as I am just doing the final fitting. The shroud is made of aluminum and it fits pretty tight around the radiator with no gaps. Should I seal it around the radiator with silicone also? Or does it need to be that air tight? There are 3 fans 2 pullers and one pusher and the front opening is 4X27. I was told that 4X20 is all that is needed. I am also making a channel from the front spoiler to the body to direct the air into the radiator. Or do you think that the air will just find its way in as I drive? Would I be better off with the channel? There is about 12" or so between the spoiler and the radiator opening on the body. Let me know what you think. After it is all installed I will go back and polish up the aluminum on the top.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 06-01-2004, 02:25 AM
grind weld build
sean_V8_914's Avatar
seaal it up, per RSH and Renegade. they recomend weather strip tape
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 06-01-2004, 06:48 AM
I'm going to seal my air inlet passage up as tight as possible and am also planning to fabricate air guides from the bumper/valence to the body opening. My idea was to try to make the main opening somewhat bigger than the body opening and maybe flair the edges somehow, but I'm not sure if it's necessary or overkill.
Ed
'74 914 V8
'70 914
Old 06-06-2004, 07:00 PM
How about if you angle the radiator back at the top so the air will get to the top more. I believe the hottest water is at the top.
Old 06-06-2004, 07:59 PM
