Okay Guys, I'm back after about a year away. I have a 74 with a 1.8 that is now a 2056. It has the original fuel injection and therin lies my questions. The car runs great but when it gets fully up to temp (oil temp of about 216 degF) and I accelerate, I get pinging. I run Premium (92 octane) with an octane booster which seems to help some. I have checked the distributor and it is advancing per specs, actually a few degrees more that the 914 factory manual states. I'm wondering if at temp and full throttle, I'm leaning out. Should I have installed the 2.0 injectors since I have the larger displacement?
Thanks for your help in advance. |
Administrator
Pinging can also be caused by a lean fuel mixture. Try checking the color of the plugs after running like that, or get to a shop that can measure the mixture.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave,
Sounds like we are on the same track. What about my suggestion of going to the 2.0 injectors? What color would the plugs be if lean, light brown? GS |
Administrator
The 1.8 and 2.0 injectors are different enough that you don't want to swap them. I have been told that Bosch used to tell their techs that swapping D-jet and L-jet injectors for each other could result in burning out some of the electrics in the FI.
Perhaps Bus injectors? I'm not sure... White is too lean, light brown is fine. --DD
At the same time I agree... it is most likely lean due to limitations in its injection system. Patrick
'74 Porsche 914 2.0l '90 VW Vanagon 1.7l Diesel |
