Burn the fire.
Procedure i'll use next valve adjustment:
-Go to TDC for #1 -hook up leakdown tester for #1 -pressurize the cylinder -set valves repeat for all other cylinders
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Member w/ Title Problems
2023 Ford F-150 Platinum 5.0 Coyote FX4 2019 Toyota Sienna XLE AWD Metal Building Erector, Recovering Porsche Guy |
Burn the fire.
From what my mechanic told me... when you pressurize the cylinder it forces the valves closed, so you don't have to worry so much about your setting being off.
Cheers, Elliot |
