FI Wiring Harness
Looking for a new, used, rebuilt FI harness for a 74-1.8 914.
Old 05-23-2000, 12:13 PM
Try res systems http://res-systems.com/
---The night time is the right time---
2000 Jetta GLS 1.8T 5speed Silver/black leather
1973 Porsche 914 HO2.0L Black/Black
1968 Camaro RS White/Black currently on the back burner until I get out of school.
Too many projects
http://www.whosnextracing.com
"Some people have shrinks, some have garages"
Old 05-26-2000, 09:57 AM
914 Geek
Last I checked, they didn't do 1.8 harnesses.
John Larson from the Rennlist posted (a while ago) this reply to a similar query:
>OK, the answer to the question is: YnZ's Yesterday's Parts, 333 East
>Stuart Avenue, Unit A, Redlands, CA 92374. Tel. 909 798 1498.
>These guys make replacement harnesses for concours weenies of all sorts...
You can also do your own to some extent. I have posted before the Beck-Arnley Worldparts part numbers for some of the electrical connectors. There might be enough to actually replicate the whole harness, if you re-use some of the plastic bits like the ECU connector.
I might as well post again. These, BTW, were gathered with my own D-jet FI in mind, but many or most of the L-jet connectors will be the same kind. You will, however, have to look to make certain.
B-A Part # Description (application) I paid
158-0002 5 @ 2-pin connector body $6
(Intake air temp sensor, etc.)
158-0003 5 @ 3-pin connector body $8
(FI Trigger Points)
158-0004 5 @ 4-pin connector body $8.50
(MPS)
158-0005 25 @ ~3mm connector pins $17
(to go in all of the above, plus TPS, etc.)
158-0006 25 @ 'V'-shaped pins allegedly for $20
the ECU connector
158-0010 1 @ extraction tool for ECU connector $5
B-A supplies a number of auto parts chains. Check around at all of your local FLAPS, someone should be able to order them. You can also order them from http://www.fuelparts.com .
In the above, I have called the metal parts that actually make the electrical contact "pins", and the plastic plug parts that the pins are held by "connector bodies".
--DD
Old 05-26-2000, 03:22 PM
