lmcchesney's Avatar
Starter problems
The starter selnioid does not activate when the ignition is turned to start. The selinoid does activate the starter when I cross the yellow wire connection (50) to the positive battery pole connection to the starter. However, when I back track to the relay board, with the ignition switch in the start position, I do not get 12v at pole 6 on the engine harness connection. From where does 6 pole of the relay board obtain 12 v from the ignition switch? Is there a fuse link between the ignition switch and pole 6?
Thanks,
L. McC
Old 09-06-2004, 09:55 AM
914 Geek
Nope, no fuse. The "signal" comes in from pin #1 of the 14-pin connector--that's the right-front pin on the right-front connector on the relay board. It also goes out to pin II (and IV?) of the four-pin connector on the right-rear of the relay board.
There seems to be some interruption between the ignition switch and the relay board. But check at the 14-pin connector anyway.
Is your car a 74 or 75? If so, has the Dreaded Seatbelt Interlock Relay been bypassed?
--DD
Old 09-06-2004, 10:16 AM
lmcchesney's Avatar
The body/electrical is a 72, so I don't believe there is a seatbelt interrupter. Does 1 pole of the 14 pin connector recieve 12v from the ignition switch?
L. McC
Old 09-06-2004, 10:21 AM
914 Geek
Yup, it should come straight from the switch.
You can pop the back of the connector off so you can check for +12V without having to unplug the connector. I don't remember if the power to the ignition switch goes through that connector or not, but if it does you obviously want to leave the thing plugged in.
--DD
Old 09-07-2004, 10:52 AM
lmcchesney's Avatar
Thanks Dave,
I found the problem. PO had cut the interrupter out and twisted the wires together, which came loose during rebuild. They are now soldered together. However, there is a relay in the area which is very warm. Any idea what the relay is? should I just remove it?
L. McC
Old 09-07-2004, 01:13 PM
914 Geek
The only two relays down under the seat I know of are the Dreaded Seatbelt Interlock Relay, and the "door ajar" buzzer. Cars without the Interlock Relay may still have some relay that controls the seat belt light.
--DD
Old 09-07-2004, 02:09 PM
