-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Help! convert tail to side shifter, need advise (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/182988-help-convert-tail-side-shifter-need-advise.html)
914hound 09-16-2004 02:18 PM
I recently got my first 914, a 71', and the tranny sucks! I want to switch it to a side shift, but wanted to get some input from all the experienced people here. What all does this switch intel? Not to bad of a swap? Any links on a how-to website, or a parts check off list? Any input would be great. Just needed a little info to put me in the right direction, after that, I should be good. Thanks for your time!
red-beard 09-16-2004 02:58 PM
Very recently discussed - Do a search as well,
Side shift tranny
late Engine mount
shift rod
shifter/gear selector in the car
special firewall bushing (OD early car, ID Late car shift rod)
Rear shift rod bushing
firewall rod cover
tranny end shift rod cover
2 CV joint gaskets & anti rotation plates
It is pretty much a bolt on
After installation, use my website for linkage adjustment
http://home.san.rr.com/pb914/
James
Dave at Pelican Parts 09-16-2004 03:35 PM
In addition to the above, you need the outboard solid transmission mounts, the inboard rubber mounts, and the brackets holding the rubber mounts to the engine case.
If you use the early-style outboard rubber mounts on a side-shift conversion, you will not be able to find all of the gears because the motor will sag down too low...
--DD
Conrad W Peden 09-16-2004 04:18 PM
good time to replace the clutch fork bushing too
red-beard 09-16-2004 04:51 PM
And the pilot bearing, the throwout bearing, clutch cable, etc. I would open up the new tranny and check out it's condition before installing in a car. Definitely replace all of the seals, etc.
James
Clay Perrine 09-17-2004 04:00 AM
Originally posted by Dave at Pelican Parts
In addition to the above, you need the outboard solid transmission mounts...
--DD
You can substitute a set of 911 solid motor mounts for the outboard mounts. Plus the 911 mounts are round and don't bend as easy.
Dave at Pelican Parts 09-17-2004 09:07 AM
Wouldn't that put the mount bar down too low? I know that's the problem when the rubber outer mounts are re-used.
The stock outboard mounts don't bend. They're U-shaped in section, and the bolts that go through them bend before the mounts do.
--DD
Conrad W Peden 09-17-2004 02:27 PM
I did the conversion on my 72 without the solid outer mounts from the post 72. Has worked for years with no problem shifting.
Dave at Pelican Parts 09-17-2004 03:32 PM
Interesting... I have heard from quite a few people who were unable to select one or more gates because the rear shift rod hit the side of the hole through the motor mount bar. Until they swapped to the late-style solid outer mounts.
--DD
914hound 09-18-2004 01:05 PM
Thanks for the replies. After actually looking at everything, it kinda took shape and sems to be pretty straight forward. Again, thanks for your time.
Clay Perrine 09-20-2004 03:46 AM
Solid mounts
Dave,
The mounts I am speaking of are flat on one side and have the extension on the other. You put them in with the flat side down.
http://www.pelicanparts.com/catalog/..._mtr_mount.JPG
Dave at Pelican Parts 09-20-2004 09:33 AM
Got it! Hmm, then maybe the outboard rubber mounts would work if you put them in upside-down??? Never thought of that!
--DD
Clay Perrine 09-20-2004 09:35 AM
You could use a solid inboard mount and the factory 911 sport mount on the outboard end. That would make it shift better too.
