I recently got my first 914, a 71', and the tranny sucks! I want to switch it to a side shift, but wanted to get some input from all the experienced people here. What all does this switch intel? Not to bad of a swap? Any links on a how-to website, or a parts check off list? Any input would be great. Just needed a little info to put me in the right direction, after that, I should be good. Thanks for your time!
canna change law physics
Very recently discussed - Do a search as well,
Side shift tranny late Engine mount shift rod shifter/gear selector in the car special firewall bushing (OD early car, ID Late car shift rod) Rear shift rod bushing firewall rod cover tranny end shift rod cover 2 CV joint gaskets & anti rotation plates It is pretty much a bolt on After installation, use my website for linkage adjustment http://home.san.rr.com/pb914/ James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
914 Geek
In addition to the above, you need the outboard solid transmission mounts, the inboard rubber mounts, and the brackets holding the rubber mounts to the engine case.
If you use the early-style outboard rubber mounts on a side-shift conversion, you will not be able to find all of the gears because the motor will sag down too low... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
good time to replace the clutch fork bushing too
We'll be having an ISO9000 audit soon. I've divided our preparation tasks into two groups: Unethical and Unproductive. |
And the pilot bearing, the throwout bearing, clutch cable, etc. I would open up the new tranny and check out it's condition before installing in a car. Definitely replace all of the seals, etc.
James
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
914 Geek
Wouldn't that put the mount bar down too low? I know that's the problem when the rubber outer mounts are re-used.
The stock outboard mounts don't bend. They're U-shaped in section, and the bolts that go through them bend before the mounts do. --DD
I did the conversion on my 72 without the solid outer mounts from the post 72. Has worked for years with no problem shifting.
914 Geek
Interesting... I have heard from quite a few people who were unable to select one or more gates because the rear shift rod hit the side of the hole through the motor mount bar. Until they swapped to the late-style solid outer mounts.
--DD
Thanks for the replies. After actually looking at everything, it kinda took shape and sems to be pretty straight forward. Again, thanks for your time.
Solid mounts
Dave,
The mounts I am speaking of are flat on one side and have the extension on the other. You put them in with the flat side down.
914 Geek
Got it! Hmm, then maybe the outboard rubber mounts would work if you put them in upside-down??? Never thought of that!
--DD
You could use a solid inboard mount and the factory 911 sport mount on the outboard end. That would make it shift better too.
