cary's Avatar
Weeping washer jets ?
The original system works. But I'm loosing fluid pressure thru the washer jet. Once the system is charged up, the jets start to weep fluid.
What am I looking for ? Switch or check valves ?
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 10-18-2004, 10:29 AM
914 Geek
Switch. The tire pressurizes the reservoir, which pressurizes the lines going to the switch. The ones from the switch to the nozzles are unpressurized; the nozzles have no valve in them.
--DD
Old 10-18-2004, 11:49 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
Agree with DD's analysis, the switch is the problem - but I'd swear that the early (chrome top) jets have a valve in them. Anyone else know?
Old 10-18-2004, 11:52 AM
cary's Avatar
Thanks Dave, thats what I thought.
The check valves just keep the lines at the jets filled ?
Cary
73 914S 2.0 AG
914 Geek
It's possible they have a low-pressure valve just to make sure you don't get air into the lines. I was only thinking about a high-pressure type valve...
--DD
Old 10-18-2004, 12:48 PM
cary's Avatar
There's a little clear check valve under each of my jets on all my cars.
Connects to the rubber sleeve under the jet. Removable.
Either chrome or plastic jets. My .02c.
Cary
73 914S 2.0 AG
Old 10-18-2004, 12:56 PM
cary's Avatar
Is there anything cleanable/repairable on the washer switch ?
Or is it a YES / NO situation ?
I'm thinking of taking one out of my parts car. But a 30 year old part, I'm have my doubts on that one too.
Cary
73 914S 2.0 AG
Old 10-18-2004, 12:59 PM
pbanders's Avatar
New switch is the fix.
Old 10-18-2004, 02:05 PM
