No Spark when the starter is cranked
I've got an odd one tonight. Been doing new fuel lines and welding the clutch tube in the tunnel. At the end I installed a hot start relay.
Now when I crank the starter there is no voltage to the coil in the crank position. Let the key spring back, starts right up. What did I do ? Any thoughts ? |
Trace the circuit back from the coil, through the relay board, to the ignition switch. Check for voltage when the starter is cranking at each place. IIRC, the aftermarket points-replacement gizmos (if you have one) require ~9V to work, while points can function much lower. (Not sure how low...)
--DD |
Traced it to the ignition switch. No volts at the coil with key in the crank position. Wiggle the key and the voltage come intermittently.
I sent an order to PP last night. |
| All times are GMT -8. The time now is 03:19 AM. |
