Send a message via AIM to Jake Seidel Send a message via Yahoo to Jake Seidel
Porsche Crest Cylnder head temp sensor
Hy my 914 is running very rich and have been looking near the pressure sensor and have found a loose black cable and I think it is the Cylinder head sensor. It is on the right side near number three spark plug. My car is a 1972 1.7 and don't know where it plugs into or how. I need a little help Thanks.
Jake seidel
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 10-28-2004, 06:14 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Yep, sounds like it unplugged. Should be a plastic connector right there for it to plug into with a white wire coming out of it.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 10-28-2004, 09:26 PM
There is a hole in the tin under the manifold cyl#3. If no wire on sensor replace it. If wire under tin pull it throgh hole and plug it in the FI harness small plastic end on an single wire. Also check vac on MPS should hold good vaccume several min. Good Luck DJ
My $400 PoMansPorshe best running/uglyest 914 runing the streets of Sarasota Fl daily!!
Old 11-10-2004, 05:55 AM
