914 914 is offline
914's Avatar
Question WTK: Need D Jet Mechanic In Los Angeles
Help, My Car Just Hunts/Runs Rich/Decreasing Power On The Freeway. Who Really Knows These Systems ?? Anyone With A
Tester ??
Thanks For Your Help,914
Old 10-24-2004, 09:10 AM
Banned
Alfred1's Avatar
John Larson may be able to help you but I'm not sure where his shop is. Others here will know.
Old 10-24-2004, 10:26 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Chech the CHT first but if its hunting and then running rich my bet is the MPS. Check it witha vacuum tester to see if it holds a 15hg vacuum for 5 minutes. If it just bleeds down its done.
Its the genade looking thing under the battery and you don't have to take it out to test it. Just unplug the vacuum hose.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 10-24-2004, 06:54 PM
914 914 is offline
914's Avatar
Can The MPS Be Adjusted For The Fuel Mixture/Rich Lean?/
My Brain Dosent Have The Mixture Screw On The Top.
Anyone With John Larsons Contact Info ??
Thanks For The Help,914
Old 10-24-2004, 07:13 PM
Bleyseng's Avatar
Yes, but it takes alot of tools to do it. Don't just adjust it for idle as its for partload and WOT Airfuel mix. If you are having idle hunting then check for vacuum leaks and or other issues.
Geoff
www.914Club.com
My Gallery Page
Old 10-25-2004, 07:01 AM
chibone_914's Avatar
Check with Alex Wong, Precision Tech in Marina Del Rey, 310-822-4566
Thank you!
John
johnechi@hotmail.com
Old 10-25-2004, 08:34 AM
914 Geek
Larson is up in Santa Maria, pretty far out of your way. If you're in the LA area, you might be able to show up at the Pelican offices and rent/borrow the D-jet EFI tester. It mainly checks the ECU... Call first, though!
Tons of D-jet info can be found here, just in case you haven't seen the link a zillion times so far.... http://members.rennlist.com/pbanders .
--DD
Old 10-25-2004, 11:19 AM
Send a message via AIM to karaoke_carlos Send a message via Yahoo to karaoke_carlos
Isn't Otto's in Venice supposed to be the best, albeit at a premium?
Old 10-25-2004, 04:27 PM
914 Geek
They're definitely good, but some people find the owner a bit hard to deal with. Even for those who do, he's still the guy to see if you want to Six-up your car and take it on the track!
--DD
Old 10-25-2004, 04:35 PM
Mail me an airline ticket will work for free!
My $400 PoMansPorshe best running/uglyest 914 runing the streets of Sarasota Fl daily!!
Old 11-10-2004, 06:12 AM
914 914 is offline
914's Avatar
Thanks Everyone For The Replys!!!
914
Old 11-11-2004, 07:02 PM
mike95125's Avatar
If its still boogered up by Jan I'll come up and fix it
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 11-11-2004, 08:21 PM
