Germain's Avatar
Fuel pump
Hello all. Simple question, I am putting an '87 Chrysler 2.2L Turbo engine in my 914 and was wondering if the fuel pump is going to be able to handle the job. Any ideas?
Old 07-20-2000, 07:19 AM
RETIRED
Joe Bob's Avatar
I don't know the engine specs, so you would need to see what the fuel pressure requirements are....a 914 FI fuel pump puts out over 35 psi....that is if it a good running one.
Most used engines will come with the fuel pump. Either way, a permanently mounted fuel pressure gauge would be a good idea. When I did my conversion, fuel pressure was one my many problems.
[This message has been edited by mikez (edited 07-20-2000).]
Old 07-20-2000, 08:03 AM
TFI TFI is offline
10 yrs already??
you need at between 35 and 50 PSI for the fuel injection on the 2.2 turbos, if i remember correctly. if you overboost it, you will need to compensate for the extra air pressure in the manifold, so the need for more pressure arises.
Old 07-20-2000, 09:54 AM
Send a message via AIM to JP Noonan
Besides pressure aren't pumps rated in volume like Liters per Hour? A weak pump can cause a lean (equals boom) condition. The 930 for example has two fuel pumps. I have the following in my car and I think it would work for you.
Carrera fuel pump. you need to buy a "Banjo" fitting with a barb on the end and two sealing copper washers to adapt it to a 914. Or, like me, use a cut off end of a 911 fuel line with the Banjo on it.
3/8" feed lines 5/16" return. Both steel lines to replace my rubtured factory plastic ones. The 3/8" fits fine in 70-74 cars but is a sqeeze in the 75-76 (mine is a 75). I think the older cars have the 9mm-3/8" line as a carry over from the 914-6. Seeing as Porsche thought it neccesary to put a 9mm line on a 110hp (carburated, I'll grant you) flat 6, your turbo will probably need at least this size of line.
MY .02 Lira
Old 07-20-2000, 10:56 AM
seems to me you need to get the specs for a chrysler/dodge motor not a 914 motor.
Old 07-21-2000, 05:44 PM
Jim Smolka's Avatar
IMHO
The reason for the 2 5/16" in a '75 is that the pump is in the front of the car On a '75 the under tank fuel filter inlet is the 3/8" (10mm) size. After that, the lines drop to 5/16"
my $0.015
Smoke Daddy
Old 07-21-2000, 06:11 PM
Germain's Avatar
I'm taking the pump off the donor car. Thanks for all the input again.
Old 07-24-2000, 05:46 AM
