Senior Member
Zendalar's Avatar
914, 1.7I revs slowly
I am a new owner of this -71 914 which has 1.7 liter (original fuel injection) engine.
The car had been standing for quite some time.. Before I started it I changed oil, cleaned sparkplugs, changed fuel, checked the distributor, spark plug cables.... Then started..
Well, it started allright at some point, idled allright, but it revs up very slowly when pedal is pressed.
My 911 is like WHAM! and its on the redline, this car, its like slowly turning the volume up on an amplifier..
Is this how it is, or is there a problem somewhere ?
Where to look?
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 01-24-2005, 12:40 PM
bd1308's Avatar
Send a message via AIM to bd1308
did you check the timing or dwell....man i swear if thats not RIGHT ON THE NOSE it runs like crap
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 01-24-2005, 02:10 PM
Senior Member
Zendalar's Avatar
So guess these cars are like...if adjusted year ago, not driven, -> The right timing/dwell is off now?
Projects:
Old 01-25-2005, 03:42 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
My bet is the advance plate in the distributor is frozen. Take apart the dizzy and clean and lube it carefully, re install and set the timing and dwell.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 01-25-2005, 07:42 AM
bd1308's Avatar
it doesnt take 10 minutes to check dwell or timing....start off with that first. PLus if the timing doesnt change with RPM, then you know that either/both the centrifugal or the vaccuum advance is sticking. or unhook the vac advance and really go after that centrifugal adv. or you could take the dizzy out and take it apart.
Old 01-25-2005, 09:11 AM
