-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   CV's, how to take them off? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/205617-cvs-how-take-them-off.html)
Andyrew 02-09-2005 06:01 PM
Since the club site is down, im resorting to here!!!
Havent been here for a while..
Anyways, The cv/half shafts...
The trani side is simple.. unbolt..
The wheel side, do you have to take the big ars nut off?? ie with a 300lb or so breaker bar?
broke mine in my v8... :D
First time! once i get it fixed im going to do my first burnout and my first dougnut! then if it breaks again, I know that its the problem and I need to get better ones!!!
:p
Andrew
skline 02-09-2005 06:17 PM
Well, you will need bigger ones I can promise you that. Anyway, you can get it out without removing the stub axle, you have to unbolt it and then use the axle like a puller. They have been in there a long time but they will come off. Good luck Andy.
Acox914 02-09-2005 06:44 PM
same 12 point tool, on a socket..... with an extension.....
at least you dint break your tranny./.....yet
skline 02-09-2005 06:48 PM
I broke 2 sets of CV's with a modified 1.7 liter many years ago. So I know your V8 will tear them apart. You could start the cheap way, use Bus axles and CV's with an adapter. It will be as strong as using ones from a 911. Just a thought.
Acox914 02-09-2005 06:57 PM
go 930's, all the high HP sandrail guys do
sean_V8_914 02-09-2005 08:41 PM
you can do V8 burn outs all day long without breaking CVs. DO NOT SIDE-STEP THE CLUTCH. from a rolling start, with clutch fully engaged, roll into teh gas pedal 1/2 way them floor it but no stomping. add a little brake and watch em bake. watch your tach! Grove st is still tatooed after all teh rain. no one leggers here!
