-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Points rubbing block rubbing off too quick (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/205898-points-rubbing-block-rubbing-off-too-quick.html)
bd1308 02-11-2005 08:03 AM
i have an actual question....my points are wearing like real fast and i cant figure out why....my dwell changes like a MoFo, and timing is way off too. Do i need a new dizzy, maybe a pertronix or what?
robinaube 02-11-2005 08:26 AM
Pertronix will eliminate the wear problem. But before you do that, are you putting any lubrication on the distributor cam? There should be a very slight amount so the block on the points doesn't wear. Just be careful not to put too much grease, you don't want the grease to get on the points themselves.
bd1308 02-11-2005 08:28 AM
yes i put lots on, run it, then wipe off excess with my finger. set dwell to 45 then it stays for a week then goes to the 50s+
boxstr 02-11-2005 08:30 AM
It should be a distributor cam lube. Yes there is a tube at your FLAPS.
You may want to check the freeplay in the dist. shaft when you have it out to replace the points.
CCLINPD
bd1308 02-11-2005 08:34 AM
the shaft is able to be pushed in, but cant be pulled out any. the push in is around 1cm (as in centimetrs) and I use the purple stuff in the points box. Everytime i ask for distributor cam lube they give dielectric grease. WTF???
boxstr 02-11-2005 08:47 AM
Find a FLAPS that has "distributor cam lube in a tube" then try that. or go to a local repair shop and get a small amount.
CCLIPD
mike mueller 02-11-2005 09:07 AM
replace the points with a pertronix or the like...it's "set and forget" which is nice :)
J P Stein 02-11-2005 10:05 AM
Points lube does not go onto the cam (tho a light coat doesn't hurt), but onto the back side of the rub block on the points. Put a glob on that step and do not rub it off. As the rub block wears, the grease will self apply.
(edit) I haven't used points in years. Pertronix is gud.
bd1308 02-11-2005 10:07 AM
can i use Di-electric grease?
J P Stein 02-11-2005 10:11 AM
Normaly, a little pill of grease comes with a set of points.
I dunno zactly what it is, but it *looks* like dielectric grease.
It's worth a shot.
bd1308 02-11-2005 10:13 AM
it's thinner than dielectric grease.....but not by much. I'm thinking about a pertronix or something, although mikeZ recommends the Crane Optical? stuff?
J P Stein 02-11-2005 10:25 AM
I've used the same Pertronix unit for ....what.....5-6 years.
2 things can fu....oops...Pelican.....mess em' up.
1) getting 2 wires crossed.
2) leaving the ignition on ( without the engine running) for an expended period.
If you can't deal with either....you're in the Zs class.:D
bd1308 02-11-2005 10:40 AM
shhh...i dont want a A$$ pic here
J P Stein 02-11-2005 11:08 AM
Mike & I have been exchanging insults for years. He keeps coming back with his stale old hairy butt cheeks & the like.
I, on the other hand, come up with a stream of fresh material.:D
BTW, Kudos to Wayne for letting us borrow his BBS while the 914club is in extremis.
Bleyseng 02-11-2005 11:11 AM
Try KY jelly as it lasts for a long time..
bd1308 02-11-2005 11:13 AM
HAHAHAHAHAHAHAHAH your not serious are you
bd1308 02-11-2005 11:17 AM
:agree: or :)
jkeyzer 02-11-2005 12:02 PM
Dude - Just get the correct grease. Or buy a new set of points (since you need them anyway) and use the grease that comes with them. It is thick, sticky stuff, way thicker than dielectric grease.
I know what happens when you don't use the right grease, it's exactly what you are seeing.
I guess make sure you are setting the dwell correctly too and don't have the points adjusted up against the cam too much.
bd1308 02-11-2005 12:14 PM
no man i have feeler guages and stuff....i've done it before. nobody knows what i'm talking about when i ask for dizzy cam grease, they give me dielectric grease.....might just pull a Dan Root and blow up all over them
Bleyseng 02-11-2005 01:38 PM
haha, dielectric grease is not the stuff to use. Dizzy cam grease is the ticket. Shouldnt wear too fast at all.
Geoff
pbanders 02-11-2005 01:44 PM
Bosch makes the grease to use. I've got a tube of it. Brown, very sticky, doesn't flow off the cam when it gets hot. Get some.
bd1308 02-11-2005 02:03 PM
from where? FLAPS barley know how to spell BOSCH
Dave at Pelican Parts 02-11-2005 02:34 PM
*ahem*
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_igniti_pg3.htm#item18
Mind you, it is about nine bucks--but it's a 10-life-times supply of the stuff!
--DD
morgan_harwell 03-01-2005 06:19 AM
Back in 1999 the distributor points in my 2.4L-6 started failing within 1000-2000 miles. The rubbing blocks were wearing out fast, causing the point gap to decrease to nothing (or was that open so wide that the point contacts never touched each other? Its been awhile.). This caused the car to stall while driving and to be hard to start at times. Not good when travelling 70-80 mph on California freeways. The weird thing was the car would die, but would re-start after a few minutes and run fine for a bit.
This was one of those times where I originally blamed the Permatune CD unit only to be proven wrong (again). After a bit of trouble-shooting I determined the CD was fine and the distributor point gap was way out of adjustment. I adjusted the points gap, and the 914 ran fine for about a month, then stalled again. The points were again out of adjustment.
I talked to a Porsche mechanic in 1999 about the points and he informed me that he was seeing numerous Bosch points wearing out prematurely due to some change in the rubbing block. It was an epidemic.
So I purchased/installed a Perlux Ignitor to replace the points and haven't had a spark problem since.
bd1308 03-01-2005 09:25 AM
i need one of those pertronix things, but I want to get something from a person here who could send it rather quickly
morgan_harwell 03-01-2005 09:54 AM
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_igniti_pg4.htm#item26
timleimkuhler 03-01-2005 10:46 AM
i am getting ready to add a pertronix to a friends 914 because after reading about the weird timing procedure you have to go through, i don't ever want to mess with it again because of points. valve adjustment will be a lot of fun i'm sure!
tim
