bd1308's Avatar
Send a message via AIM to bd1308
Points rubbing block rubbing off too quick
i have an actual question....my points are wearing like real fast and i cant figure out why....my dwell changes like a MoFo, and timing is way off too. Do i need a new dizzy, maybe a pertronix or what?
According to Google, "I" am Mike Mueller
1974 914 with 72 1.7 and 74 L-Jet system (vroom)
Old 02-11-2005, 09:03 AM
Pertronix will eliminate the wear problem. But before you do that, are you putting any lubrication on the distributor cam? There should be a very slight amount so the block on the points doesn't wear. Just be careful not to put too much grease, you don't want the grease to get on the points themselves.
Rob
'90 964 Cabrio - daily driver 220K miles
Old 02-11-2005, 09:26 AM
bd1308's Avatar
yes i put lots on, run it, then wipe off excess with my finger. set dwell to 45 then it stays for a week then goes to the 50s+
Old 02-11-2005, 09:28 AM
It should be a distributor cam lube. Yes there is a tube at your FLAPS.
You may want to check the freeplay in the dist. shaft when you have it out to replace the points.
CCLINPD
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 02-11-2005, 09:30 AM
bd1308's Avatar
the shaft is able to be pushed in, but cant be pulled out any. the push in is around 1cm (as in centimetrs) and I use the purple stuff in the points box. Everytime i ask for distributor cam lube they give dielectric grease. WTF???
Old 02-11-2005, 09:34 AM
Find a FLAPS that has "distributor cam lube in a tube" then try that. or go to a local repair shop and get a small amount.
CCLIPD
Old 02-11-2005, 09:47 AM
mike mueller's Avatar
replace the points with a pertronix or the like...it's "set and forget" which is nice
'73 914, 1.7, with Boxster transmission in the future?
Old 02-11-2005, 10:07 AM
Points lube does not go onto the cam (tho a light coat doesn't hurt), but onto the back side of the rub block on the points. Put a glob on that step and do not rub it off. As the rub block wears, the grease will self apply.
(edit) I haven't used points in years. Pertronix is gud.
JPIII
Early Boxster
Old 02-11-2005, 11:05 AM
bd1308's Avatar
can i use Di-electric grease?
Old 02-11-2005, 11:07 AM
Normaly, a little pill of grease comes with a set of points.
I dunno zactly what it is, but it *looks* like dielectric grease.
It's worth a shot.
JPIII
Early Boxster
Old 02-11-2005, 11:11 AM
bd1308's Avatar
it's thinner than dielectric grease.....but not by much. I'm thinking about a pertronix or something, although mikeZ recommends the Crane Optical? stuff?
Old 02-11-2005, 11:13 AM
I've used the same Pertronix unit for ....what.....5-6 years.
2 things can fu....oops...Pelican.....mess em' up.
1) getting 2 wires crossed.
2) leaving the ignition on ( without the engine running) for an expended period.
If you can't deal with either....you're in the Zs class.
JPIII
Early Boxster
Old 02-11-2005, 11:25 AM
bd1308's Avatar
shhh...i dont want a A$$ pic here
Old 02-11-2005, 11:40 AM
Mike & I have been exchanging insults for years. He keeps coming back with his stale old hairy butt cheeks & the like.
I, on the other hand, come up with a stream of fresh material.
BTW, Kudos to Wayne for letting us borrow his BBS while the 914club is in extremis.
JPIII
Early Boxster
Old 02-11-2005, 12:08 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Try KY jelly as it lasts for a long time..
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 02-11-2005, 12:11 PM
bd1308's Avatar
HAHAHAHAHAHAHAHAH your not serious are you
Old 02-11-2005, 12:13 PM
bd1308's Avatar
:agree: or
Old 02-11-2005, 12:17 PM
jkeyzer's Avatar
Dude - Just get the correct grease. Or buy a new set of points (since you need them anyway) and use the grease that comes with them. It is thick, sticky stuff, way thicker than dielectric grease.
I know what happens when you don't use the right grease, it's exactly what you are seeing.
I guess make sure you are setting the dwell correctly too and don't have the points adjusted up against the cam too much.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 02-11-2005, 01:02 PM
bd1308's Avatar
no man i have feeler guages and stuff....i've done it before. nobody knows what i'm talking about when i ask for dizzy cam grease, they give me dielectric grease.....might just pull a Dan Root and blow up all over them
Old 02-11-2005, 01:14 PM
Bleyseng's Avatar
haha, dielectric grease is not the stuff to use. Dizzy cam grease is the ticket. Shouldnt wear too fast at all.
Geoff
www.914Club.com
My Gallery Page
Old 02-11-2005, 02:38 PM
