ChrisFix's Avatar
Turn Signal Indicator Light Stays On
The green turn signal indicator light in the tach gauge on my '74 1.8 stays dimly light whenever the ignition is on. The turn signal lamps all work correctly and the indicator light flashes brightly with the relay when the turn signal is on, but it always glows dimly when the signal isn't on. I have no idea where to begin to diagnose the problem. Anybody else have this/fix this on their car?
Thanks,
Chris
Old 03-08-2005, 01:29 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
I would pull the tach out and pull the light and holder while the car is running to see if the light is really on or if maybe your maybe getting light from another source
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 03-08-2005, 11:39 PM
Bowman74's Avatar
Chris,
I had this problem for a while as well. I replaced the turn signal relay and the problem went away.
Thanks,
Kevin
Old 03-10-2005, 12:22 PM
ChrisFix's Avatar
Thanks! I spoke with a couple of others who said the same thing regarding the flasher relay. According to George Hussey of AA, there is a diode in the flasher relay that leaks current, and keeps the indicator glowing. I've ordered the part and will keep my fingers crossed that it's fixed.
- Chris
'74 1.8 Ravenna Green
42K Miles Young
Old 03-10-2005, 01:49 PM
