Control arm bushing replacement
There is a big discussion on the 911 board about control arm bushings. One of the things that came up was that the bushings for the 914 and the 914 are the same.
My question is, what do you 914 guys do for an inexpensive alternative for the factory rubber busings. I don't want to spend the coin for polybronze, or new control arms. Thanks, Mark |
I purchased the poly bushings at pelican. There about $40 for a set of 4. If you've never replaced yours before, you will need a torch to get the old ones out. After removing the suspension arms, you just burn the bushings for a minute and then they pry out with a screw driver.
The new bushings shoud be greased before installing and that will prevent sqeaks. I did mine about 2 years ago and they've worked out fine. And, my car no longer squeaks over every bump. Vern |
The poly bushings are relatively inexpensive. They will squeak, though. Vern's experience is somewhat atypical (unless they start squeaking next week, in which case it's somewhat typical). Even when you grease them, they seem to start making noise after a year or two.
The bronze bushings or the roller bearing ("Mueller bearing") setups are other possibilities. Or replacing the stock bushings, which means replacing the stock A-arms. BTW, it's only the front suspension which is (more or less, somewhat less than more) the same between the 911 and the 914. The rear is vastly different. I don't think Elephant Racing makes rear trailing arm bushings in bronze for our cars. Poly, roller bearing, or stock (replace the trailing arm) are your choices, there. --DD |
I don't have any links handy...
but most of the 914ers that go poly, end up installing zerks and grooving the bushings to help facilitate reguar re-greasing. I used to not have zerks and had to dissassemble 1x each year to re-grease. brant |
Thanks for the input guys. That's what I was afraid of. Looks like options are limited for going back to stock.
Anyone know the approximate cost of new arms with stock rubber bushings (front and rear)? Too high to even consider?
Or within the realm of possibility if you are an OE freak like me? |
How deep are your pockets?
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_suspen_pg4.htm#item18 ...I assume the trailing arms would not be cheaper than the A-arms... --DD |
Not that deep.
| All times are GMT -8. The time now is 05:35 AM. |
