ALFA FLAT-4 IN 914
Does anyone know if someone has put an Alfa Romeo flat four engine in a 914?
Bruno
Old 10-30-2000, 07:03 AM
Why would you want to? Only thing on earth (besides British cars) that requires more maintenance than a Porsche is a Fiat.
Flame on.
Old 10-30-2000, 05:03 PM
o
Oh my! Oh my! What would Dr. Porsche think?
Old 10-30-2000, 06:18 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
...And this, from someone who turbocharged a 2.0 914 motor (with a side-draft carb, yet!) and is now playing with a Chevy V-8 in a 914.
Heh heh heh heh. Are the Powers of Orthodoxy starting to win you over, Sammy?
--DD
Old 10-30-2000, 07:51 PM
Unregistered
sammyg2's Avatar
Yea, I guess I shouldn't talk.
I drove a buddy's Fiat in high school for a while, biggest POS i ever climbed into. I shouldn't judge all of them by that hacked up piece, but I have never got it out of my system.
Old 10-31-2000, 04:37 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
How about a Tatra Aircooled OHC V-8 3.5 liter?
Old 11-19-2000, 08:54 AM
Send a message via ICQ to randoid
Oh, Fiats aren't that bad. Some models have rust problems, but not all. We had a 131 that was a lot of fun... well... until the exhaust pipe broke in three pieces, and when the oil pickup tube shattered. hmmm...
Randy
Old 11-19-2000, 07:00 PM
To get back to the original post, this guy wanted to put an Alfa flat-four in, which is an honest-to-God Alfa engine, not a badge-engineered modern FIAT engine. I don't know that FIAT ever made a flat-four. But the Alfa Sud flat four is reputed to be a great engine, though the car bodies rusted away around the engine. They had a single overhead cam one each side, all I think had dual carbs and some had FI. They're water-cooled, which would be a challenge, and I wouldn't personally want to try the swap. Suds were never sold in the US, though there are two or three around. The engines are small displacement compared to any 914; the first were 1100, I think, and grew eventually to 1600. The same basic engine was used in the later 33 models. Tons of them in English and Italian junkyards, I'd think.
Andrew Watry
lots o' Alfas
one Porsche
Old 11-21-2000, 09:08 AM
A water cooled Alfa Sud boxer has genuine cred in a 914, because it was a Porsche design project for AR. Methinks the transaxle with in-board disc brakes was also a Porsche project, because the Sud was Alfa's first front driver.
Car was built in a new plant in Southern Italy (hence Alfa Sud) to alleviate chronic unemployment.
Fantastic to drive (though a bit underpowed), it was full of Alfa advances like properly sorted front strut suspension, responsive steering and in-board front brakes. Flat four engine alllowed a super-rigid body design. You yanks would have loved them.
Downside was crappy build quality which allowed tin worms to take quick hold in early models. Later cars were much better.
Engine is a gem. Loved to rev, super-rigid one-piede iron case, cross-bolted mains. Con rod caps are a work of art!
In Oz, later Suds and the Alfa 33 evolution went to 1750 cc capacity with DOHC and EFI. Engine was still around in the late 80s in an Alfa Romeo / Nissan joint venture.
Quite a few Alfa-powered V-Dubs and specials in Oz, although the Subaru flat four is now the go, due to better availability and bigger capacity.
For something completely different, Citroen built a car called a GS (like a stumpy CX), with an air-cooled flat four. With SOHC and roller bearing crank, this was a bloody ripper even from 1200 cc and just wanted to go and go.
Old 04-22-2005, 06:34 PM
Banned
Alfred1's Avatar
Anyone have a picture of this Alfa motor? I like the idea of a one-piece case. I think a cool new flat-four would be one with a one-piece case that also incorporated the "Lanchester design" to eliminate the rocking couple produced in a normal flat-four.
Old 04-23-2005, 08:03 PM
Banned
Alfred1's Avatar
I just found some info on the Alfa motor.
Engine and Transmission
Liquid-cooled four cylinder Boxer-engine (horizontaly opposed). One piece cast iron engine block / crankcase. Three-bearing steel crankshaft in steel backed tin alloy bearings. Light alloy cylinder heads. One overhead camshaft per row (driven by one toothed belt each). Two valves per cylinder. Directly operarting on oil bath cups. Stellite faced exhauset valves. Hydraulic tappets (for Sprint 1.7 QV / 1.7 IE QV only). Lubrification: wet sump pressure and splash, full flow replaceable cartridge. Oil capacity 4,5 litres (incl. filter charge). Water radiator; electrically driven, thermostatically controlled fan, mechanical, belt-driven pump.
Carburation: (depending on version) vertical single-barrel carburettor, one or two twin-choke downdraft carburettors or Bosch LE 3.1 Jetronic (Sprint 1.7 IE QV only). Firing order 1 - 3 - 2 - 4. Since 1980 the Ti and Sprint-versions are sold with a breakerless ignition.
Sprint 1.7 QV ie
(3-way-catalyst) (1988)
Capacity (cm³) 1712
Bore (mm) 87
Stroke (mm) 72
Power Output (DIN-bhp - rpm) 105 / 5500
Torque (mkg-DIN - rpm) 14,8 / 4500
Torque (Nm-DIN - rpm) 145 / 4500
Carburation Bosch LE 3.1 Jetronic
Top Speed (kph) 188
Tank Capacity (l) 50
Fuel Consumption at 90 kph / 120 kph / Urban Cycle ECE 9,9
Tyres (optional) 185 / 60 HR 14
Kerb Weight (kg) 915
Overall Length x Width x Height unloaden (mm) 4024 / 1620 / 1297
Track front / rear (mm) 1397 / 1364
Wheelbase (mm) 2455
Boot Capacity (l) 325
Towing Weights unbraked / braked (kg) 915 / 940
Trailer hitch tongue load (kg) 50
Roof Weight (kg) 80
Old 04-25-2005, 05:35 PM
