V8 Help!
Scott? Sean? Ian? I'm transplanting my conversion parts from the 238 to the 350. The 350 has a Milodon cam drive. When installing the harmonic balancer/belt pulley I found the new engine has 1/4" less shaft length which miss-aligns my alternator and w/p belt alignment 1/4". I know there is a crank gear but I don't think Milodon would require you to install a shorter h/b. I "could" space out the alternator and w/p but may cause interference to the bulkhead. Will the h/b be okay mounted 1/4" off the shaft?
Felix 1974 914 250hp 2.7tt Audi conversion, neo914-6 concept 1990 300CE, 217hp AMG 3 piece wheels 1988 300TE, 260hp RENNTech 3.6L 1990 300E, 185hp stock |
Felix, I am not 100% sure on this, my 283 didnt have a hole drilled and tapped in the end of the crank to use a bolt to hold it on. The later 350's did. Mine is a press fit.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
grind weld build
Kennedy Engineering, Renegade and Desert Hybrids sell HB spacers of different lengths. I think Desert Hybrid spacers are cheaper and nice pcs
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
Sean,
I found out the crank drive "is" the spacer, LOL. I plan to machine down the h/b stub 1/4" to keep everything aligned and not reduce my limited engine to bulkhead clearance. See you at WCC, w/o my car... ![]()
grind weld build
you can make it...with your car.
Well this isn't the only obstacle. The bigger one is the 8" vs 9" mistake that KEP and I made. I actually had it figured out months ago but they told me the part numbers I provided are 9". I guess I "wanted" to believe them and should have removed mine first. Anyway, the short of it is I will have my Jaide flywheel modified to fit their 8" double disc and pp. This will take days I don't have prior to WCC. I also found some water fittings that are corroded that I will need to replace. Oh well, could've should've started earlier but life doesn't always cooperate...
![]() At least I've finally got my garage cleared, somewhat organized, engine replacement started, and have momentum. This is good gearing up for my other conversion project...
Felix 1974 914 250hp 2.7tt Audi conversion, neo914-6 concept 1990 300CE, 217hp AMG 3 piece wheels 1988 300TE, 260hp RENNTech 3.6L 1990 300E, 185hp stock Last edited by Felix; 04-18-2005 at 03:27 PM.. |
grind weld build
Thread Tools | |
Rate This Thread | |
