-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Do I really need all this engine tin? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/226735-do-i-really-need-all-engine-tin.html)
tmeracz 06-16-2005 02:16 PM
Like the title says...
I have it all off to replace an alternator. Judging by how much fun it was to take off, I just can't imagine what a blast it's going to be to put back into place. I especially loved the rusted-in flathead screws... that touch alone was an A+ in my book. Suffice it to say that my skin still reeks of penetrating oil.
So, anyone onlist running their 2.0 without engine tin? Any difference in engine operating temperatures? Bear in mind this is a SoCal car and we are on the doorstep to another hot summer.
Also if I don't put this stuff back on, is anyone onlist interested in it? Otherwise I'll just be welding it into a hibachi.
Dave at Pelican Parts 06-16-2005 03:03 PM
You need it. All of it. Otherwise you'll massively overcool some spots of the engine (e.g., right by the fan) and massively undercool (i.e., massively overheat) the rest of it. You will also re-ingest air that has already taken some of the engine's heat with it and try to cool the engine with that. And you won't get much if any flow through the oil cooler.
Keep the engine tin. I replaced the slot-head screws with Allen-heads and have been somewhat happier when I needed to remove the tin again later.
--DD
Tidybuoy 06-16-2005 03:18 PM
You definitely do NOT want to get rid of any engine tin. That would be a complete disaster if you got rid of the tin and your engine would run extremely hot for a short while and then not run at all.
The engine tin might not look like it's that important but it is. The cooling fan blows a lot of air but the tin is what directs the air to the right places (ie., the cylinders & heads). You'll notice that the tin pretty much encases these parts and that is how the fan get the air to the right spots.
I would recommend that now that you've got it all off the engine, paint or powder coat it and clean things up. If you didn't drop the engine, that's probably why it was such a big project. It's much easier to do with the engine dropped.
Should you decide to toss the tin....I could use some 2.0 tin pieces. Send them my way (lol).....
Anyone else with comments?
Vern
Curt914 06-16-2005 06:42 PM
Question for Dave
I will soon be putting my engine tin back on the engine(that is now out of the car). How do I find the allen head screws that you refer to. I really dont want to put flat heads back in.
Also, in a post made long ago about replacing fuel line, you mentioned putting the same plastic line that is already in there only new. I agree given how long the old line lasted.
Do you know where to get that kind of plastic line?
Curt
degreeoff1 06-16-2005 07:16 PM
DO NOT LEAVE IT OFF!!!! oh yeah, even though those llil pieces under the cylinders don't look important(between the cyl and pushrod tubes) ....they are
Josh
jamcleod 06-17-2005 06:54 AM
you shouldn't have to remove but 2 (or 3) pieces of tin to replace the alt. one piece is the section on the front to allow access from below and then the piece in front of the alt.
John Rogers 06-17-2005 07:10 AM
Those are "cheese head" screws. Try finding some of those at a parts store....
Dave at Pelican Parts 06-17-2005 09:22 AM
They're M6 screws, I forget the thread pitch. I went to my local metric harware supplier and told him I wanted something "exactly like this" (handed him the screw) "but with an Allen head". Bought a baggie of 100 of them for something like ten or fifteen bucks.
The stock plastic lines for the 70-74 cars are, as far as I know, now NLA. You will have to either fake it using the 75-76 plastic lines, or replace them with something like truck brake lines, per the tech article elsewhere on this site.
--DD
Joe Ricard 06-22-2005 04:25 AM
Running a tap in the holes of cheese head screws makes life easier next time. As far as getting them out? IMPACT DRIVER.
You don't need no tin as long as the engine is OFF.
tmeracz 06-23-2005 01:21 PM
Heh, OK guys, no hibachi then- at least as long as I keep running this air cooled masterpiece.
Riddle me this: would the engine survive a trip (about a block and a half) to my local car wash for a thorough degreasing with that tin off?
Or am I looking at rolling the powertrain up there on a furniture dolly?
bd1308 06-23-2005 01:30 PM
i'd pop off your rear window and spray water onto the engine jugs so they cool down. I personally think it would work, if you started it DEAD COLD.
AaronM 06-23-2005 02:08 PM
I sure wouldn't do it with the FI connected... Wouldn't trust that stuff for a second with high-pressure water.
Also, cold water on a hot engine wouldn't be good.
Dave at Pelican Parts 06-23-2005 02:17 PM
I've no idea how well it would survive. It probably wouldn't explode. It also probably wouldn't be real happy. And you'd have to figure out how to bolt up all of the FI parts without the engine tin there, then mask them off or remove them before you started hosing away... Carbs would be simpler, to an extent.
I'd consider taking it over on a pallet or dolly. You'll be able to get to much more of the engine without that pesky "car" in the way! ;)
--DD
tneffhoe 06-23-2005 03:18 PM
Go to any VW bug shop, ask for cheesehead screws.
Tidybuoy 06-23-2005 03:33 PM
Why not just degrease and clean it at home. I just got finished cleaning an engine with degreaser and a good strong hose. It worked fine. I have also hooked my hose up to the hot water faucet for the washing machine and I have gotten things spotless.
That's what I would do................................................ Vern
tmeracz 06-23-2005 04:09 PM
Well, that's a possibility, but that grease has to go somewhere... that generally means the floor. Then my dogs run through it and track it into the house & the bed... then I end up sleeping on the couch because my girl is pissed...
Plus I live in a condo so that degreaser stinks up all 3 floors like nothing else. Mean Green seems to work, but it needs a few days to soak & I really don't have the time to disassemble this thing completely right now.
So I'll forgo the drive. Sounds like I'll be degreasing on Sunday but I'll lay out something disposable, like the LA times.
Anybody know of anything non-stinky to degrease with?
Thanks for all the input.
NoEcm 06-23-2005 04:20 PM
If I were rebuilding an engine or anything else with lots of dirty parts that needed cleaning I would go to Craig's list and look for a free used working dishwasher (a portable would be best) and use some of that water soluble degreaser in it to clean all my parts. It's amazing how many people in Seattle will give away their old working dishwashers when they are upgrading or remodeling.
I've found Industrial strength concentrated degreaser at Sam's club or Costco for ~ $5 a gallon. Mixed with water 1 gallon of degreaser makes 30 or so gallons of cleaner.
Connect the dishwasher to a hot water source, add some degreaser and wash parts. If you're washing steel parts you'll have to make sure you dry the parts as soon as it's done washing before they start to rust. If you bead blast your parts, washing them first will keep the dirt, grime and oil out of your bead blaster.
After you're done with the dishwasher you can send it to the appliance recycle center.
Look for your nearest major city and look in the free section:
http://www.craigslist.org/
tmeracz 06-23-2005 05:45 PM
That's a really cool idea! What 's the shelf-life on a rig like this- assuming that you have a used unit in your hands that works?
NoEcm 06-23-2005 07:06 PM
I would guess that the life of the unit would depend on its condition before you got it.
The green (I think they called it Avocado) portable dish washer that I used lasted for 2 VW engine rebuilds over the course of a year without leaking before I got rid of it to save garage space. Sometimes I wish I still had it.
The upper and lower racks were good for supporting the parts and the silverware container held the small parts nicely.
The most vulnerable area to this would be if there was a small leak in the dish washer's main seal the degreaser could also "degrease" the main bearing which would eventually lead to it's failure. It could go a long time with a noisy bearing though.
Most of the parts came out really clean with one washing. The really dirty parts needed 2 washings.....especially if your parts are really greasy and the degreaser gets over saturated. Overall it did a great job.
Make sure that you use water-soluble degreaser and keep your water hot. BTW, the degreaser at Sam's club and at Costco is in the section with the clothes detergent and the Janitor's cleaning supplies.
Good luck!!!!
Dave at Pelican Parts 06-24-2005 07:50 AM
Hmmm.... There might be some issues with getting that grease into the regular waste water system. You might wanna check with the local environmental laws on that; it may technically be toxic waste.
--DD
NoEcm 06-24-2005 08:43 AM
--DD
Sorry, I left this part out: As the portable dishwasher was being used in my driveway the drain was not connected to the city sewer system. Instead, the drain hose was routed to a 5-gallon bucket. I used 1 bucket for the wash cycle and 1 bucket for the drain cycle. After the cycles were complete I left the buckets outside to evaporate. After the evaporation process I was left with some "goop" (most was in the wash cycle bucket) which I scooped into a plastic jug and marked "old grease". On most weekends the county here has a free "Wastemobile Collection Event" where they have a collection truck parked in various locations and you can take your hazardous waste there for collection and disposal.
For the folks living in the Seattle/King county area:
http://www.govlink.org/hazwaste/house/disposal/wastemobile/index.html
tmeracz 06-28-2005 11:40 PM
So I'm taking the safe route and washing it down in the garage. Lots of Mean Green and a drip pan to keep things sanitary. I took about a half inch of "mulch" from the top of the engine. I never knew this engine block was silver!
norustscott 08-02-2005 05:21 PM
....i would drive it ever so gently, as in no more than 2500 rpm and start with a cold engine. for a couple of miles even, turn it off at stop lights I have seen air cooled engines run without cooling on the drag strip and HARD too. 2 minutes in the staging lanes and 12 seconds full throttle and another 2 minutes in the return lanes...
tmeracz 08-02-2005 05:47 PM
Thanks for weighing in
Thanks for weighing in on this... but the job is nearly done.
I'm sidelined right now because of a dented injector housing in my left intake mani, but that will hopefully get cured this week.
I wouldn't compare this rickety old 2.0 to a dragster- those air cooled monsters are running forged pistons, chamfered cranks & shot-peened connecting rods for sure. And they usually rebuild them after a weekend of running them hard, if they don't run in a bracket that lets the teams yank the motor outright between passes and replace it with a fresh block.
norustscott 08-03-2005 06:18 AM
you are selling your engine short...first your 2.0 is not rickety. in fact it is very stought and considering you still have the fan blowing air to the oil cooler it really is not that bad for a short run. The drag racers...most don't tear down after each race....most are less than 2 liters...most do not run a fan. I have even run without the belt to keep from exploding the fan its self at high rpm...have you ever watched one of those engine blow contests...the ones you have to gues how long the engine will last at full throttle and no load? most go for more than 10 minutes!
Your talking about driving two city blocks...and not at full throttle...you would be fine.
Having done that task numerous times I know how messy it is. My concrete driveway has the stains to prove it...good luck.
Scott
tmeracz 08-03-2005 11:43 AM
Maybe I am selling the 2.0 short- I'm sure it's a good engine in it's own right when moderately or fully built. I based my "rickety" judgement on the fact that I know this car since I was born, and believe me, the best thing my uncle ever did for this thing was park it for 17 years. Cap, rotor & plugs done maybe once in its life, I don't think the valve covers were ever cracked for an adjustment- for shame. I'm the kind of guy who hand polishes the VTEC solenoid on my B16 while I talk to it ever so gently, so it pains me to see this kind of neglect.
I just know that air-cooled is not for me. I'm getting it back on the road and saving up for a water-cooled transplant ASAP. More power, more bang for the buck than building an original spec flat six for this 914, or even than going through the motions of rebuilding this 2.0 from the ground up.
I already have a tinker car with the Honda, and believe me, I've done a LOT with a little engine there: 1.6 liters puts out 193whp @ 9500rpm-enough torque to shred the rear crossmember after 3 years of hard driving on a six-puck unsprung clutch. She's waiting for a one-off chromolly custom piece that will give me adjustable height for the steering rack too, so I can kiss bump-steer goodbye. I miss driving that car... it's handed many a BMW it's ass in the canyons.
Next, I want to build something without the inherent problems of small displacement. I want a 3+ liter cruiser, probably forced induction as well, with big brakes and the widest, blackest set of cookie-cutters I can stuff under those GT flares. I'm leaving it that screaming orange color to scare the valets.
So you're running the 1320 w/out a fan? That somehow doesn't surprise me- drag cars have any manner of sane parts missing. :-) But if you're worried about blowing it up when you hit high RPM, you may want to seriously consider getting the rotating assembly harmonically balanced at a machine shop you trust. If it's a street car/weekend warrior, it would do wonders for the longevity of that block in general. Anyone I know hitting 11 & 13 grand redlines on a Honda B-series has dropped serious $$ on bottom end prep. I don't know if you touched this when you rebuilt it, but I would imagine that a 30+ y/o motor would have some pretty amazing tolerances worn into the crank & the bearings too after so many years of use. Or even if it was new or low mileage, I've been amazed at how much tolerance will pass muster from the factory. Blueprinting is worth every hard-earned cent you drop into it.
OK, now back to cleaning up the 914. I smell like Simple Green...
mike mueller 08-03-2005 02:22 PM
I know of a few /4 motor'd 914's not running all of the engine tin...of course they have headers that have been ceramic coated to help minimize the hot air coming back up into the engine compartment...mosty auto-x, but they do see street traffic, no reports of problems...but for a stock motor running the stock heatexchangers I wouldn't recommend it....
well, not too impressive since the cookie-cutters only came 6" and 7" wide :)
good luck on the conversion to watercooled..there are tons of sweet motors that make cool conversions....just stay away from the VR6, motor is too damn tall...it fits (BTDT), but I didn't like it so I sold it.
tmeracz 08-03-2005 03:07 PM
Ceramic coat on headers
What a nifty, nifty idea!!!
I have a TON of exhaust thermal wrapping lying around. I'll give those headers & heat exchangers a seeing-to while she's apart. Maybe even wrap up the intake mani runners. I love the spray-on coating that came with this kit. When it heats up it smokes & smells like burnt cookies... Yum!
Regarding the wheels- I don't need 12inch meats in the back to be happy, just something more substantial than these spindly wheels it rolls on right now.
How much is too much for a set of cookie-cutters? They don't need to be perfect as they'll probably get machined & powdercoated black.
mike mueller 08-03-2005 03:54 PM
average cost of cookie-cutters is about $200 for all 4
FYI, with an adapter plate, you can install a Honda motor into your 914....most of the 4 bangers turn the wrong direction, but I know the V6's and one of the newest generation 4 banger does turn the "correct" way..... I wouldn't do it, but I'm sure someone will one of these days.....
tmeracz 08-03-2005 04:15 PM
Heh, and if it would be any krackhead... it would be me.
The newer iVtec K series is the engine you are talking about.
I think either a newer water-cooled Porsche engine or a WRX swap is it for me.
What was your major gripe w/ the VR6? My g/f had one in her Jetta. Plenty o' grunt, but I think it could have used a turbo for those "special" times.
Thanks for the intel on the wheels, BTW.
Dave at Pelican Parts 08-03-2005 09:31 PM
That's a stout B16, there. Sometimes I wish I had a B-series in my CRX... A lot like your Civic, but lighter and smaller!! :D
--DD
tmeracz 08-03-2005 11:23 PM
If you have about $2400 to do it right, the B16 is a good swap even in its stock form. Even better, put it in a 86-87 Rex. There's more fabrication involved, but it's an even lighter car. My hatch is gutted and now a 2 seater, but with my g/f's reaction to the spring rates I just shoehorned onto the coilovers (600lbs frnt, 700lbs rear) it may just be one Recaro seat up front real soon. Who needs a "navigator" anyway... right?
I like the Rex but honestly I have to say it's better for the drag strip. There's something a little twitchy about it's shorter wheelbase in a hard corner during an autoX/togai run session. Suffice it to say that I've broken traction a lot easier with my rear wheels in a Rex than with my hatch. Although I haven't yet cornerweighted the car or scheduled some skid pad sessions, similar setups to mine will pull 1g of lateral force before breaking traction on good tires. That, my friend, will punk on a Ferrari... all day.
The B16 also adds about 100lbs to the nose of the car and that won't go unnoticed with your car's predisposition to oversteer. Build up a single cam D16 for the best of both worlds. My buddy runs a red Rex that I helped rebuild. He spent about $5k on the bottom end and headwork, but he's getting 186whp with a torque curve much healthier than mine, due to the longer stroke of this motor.
The downside is: his setup won't stand a piss of a chance smogging, won't run on pump gas and it's tuned within an inch of it's life. That is one advantage to a mild build on a B16- it will push healthy numbers- as high as 215whp without sacrificing legality or integrity.
CARB will now sanction all JDM B16's as long as you upgrade your ECU and smog system to OBD1, have a CARB legal exhaust, header and intake mani, and pass all the sniffer tests at idle and 2500rpm. The best trick with the DOHC B16? Leave the primary lobes of the cam untouched- CARB tests don't pass the stock RPM threshold for VTEC engagement. Get as nasty as you dare with the secondary lobes- it's where the fun happens anyway. Just make sure you give the rest of the head "the treatment".
*I will not rest until my 914 has extended wheel lugs and a nice side-exit canister exhaust like all those WRX's I see tooling around. Kraut is so nice- with some rice!
Dave at Pelican Parts 08-04-2005 08:08 AM
But oversteer is fun!! At least it's one way to get that understeering mother of a car to turn...
Ob914Content: My 914 could do power-on oversteer. In the wet, or when the tires were really dead. That was lots of fun, dirt-tracking around the corners! Not sure I can do that anymore with my new-to-me Azenis tires. It'll be fun to find out, though!
--DD
mike mueller 08-05-2005 05:04 AM
The VR6 engine is really tall for the 914 engine compartment, I got it to fit, but I didn't like the install...so I sold it and decided to stick with the stock motor (sorta stock :) Nickies, which are aluminum cylinders, custom cam w/ceramic lifters, aftermarket fuel injection......etc...etc....)
Check out this thread here:
audi/volkswagon W8 and W12 motor discussion
Had I known about the W8 motor, I think I would have gone down that path, but I have too much money into my /4 right now.
http://www.914club.com/bbs2/uploads/...1123199285.jpg
