Overhauled Engine Noise
I have just finished a complete overhaul of the fuel injected 1.8 liter engine from my 1974 914. I reused the pistons, honed the cylinders, and installed all new rings, bearings, gaskets, and seals. All fits and clearances are within factory limits. The engine is reinstalled and I have set the dwell, timing, and valve clearances. It is running very well except for one thing.
I now have clatter (or a slight mechanical rattle) that ONLY occurs between 2000 and 3000 R.P.M. during deceleration. If I apply any amount of throttle the noise goes away. I have combed the entire engine compartment and undercarriage for sources. Other than the torsion bars for the engine lid and rear trunk lid, which now have rubber hose insulators installed, I can not find anything else moving or hitting other parts. If anyone has a suggestion I would be very grateful. SmileWavy |
I have a similar noise at similar times in my 2.0. Some people tell me it might be a wrist pin others the windage tray due to the gasket being old.
-Roger |
Roger,
Is the windage tray the metal plate inside the engine case that keeps the oil from being mixed up by the crankshaft? If so, I just replaced those edge seals during the rebuild. I also just checked the wrist pin clearances. Thanks for your reply, anyway. Andrew |
You might have a loose bolt or nut on the exhaust system.
I have found this to be wrist pin. Usually not a problem and can go on for years
Did you have the case/heads thoroughly checked by a machine shop before rebuild? Are the main bearings still standard? How many miles did it have on it total before this rebuild?
As you can see, I have tons of question... |
| All times are GMT -8. The time now is 02:01 AM. |
