Header temps @ the head
I had a CHT gauge that I used in my IV that work well. For my SIX conversion I installed the TC on the header as close to the head port as possible on #3 cylinder.
Just wondering what range of temp should I be looking for. I can idle at 350 and jump to 500 very quickly if I hold the rpms at 2500 Thoughts? |
CHT or EGT???
cht = cylinder head temp. UNDER YOUR SPAKPLUG EGT - PROBE in the HEADER that tells you EXHAUST GAS TEMP |
CHT.
Under the plug was not an option so I installed it high on the header. I figure it would give me some indication. Once I get a baseline temp I will then be able to tell if something is going wrong. |
egt's get way hotter than heads.
bad idea.... and its not setup right for CHT then is it? its giving you a nonsense reading of the header temp...NOT head temp |
Exhaust gas temp is usually between 1400(rich) - 1600(lean) degrees....any correlation...don't think so.
CHT, oil temp and pressure are the big three......an air/fuel gauge is a better gauge for lean verus rich.
I know this is a little dated of a topic, but can anyone explain some specifics of a CHT, as far as where the sender would mount (need to drill into the head, or does it surface mount?). I am talking about something aftermarket for a gauge, not the CHT for the computer.
Grant |
most CHT's have a thermocouple ring that goes UNDER a sparkplug. this gives a very accurate reading.
| All times are GMT -8. The time now is 08:15 AM. |
