Va914's Avatar
Header temps @ the head
I had a CHT gauge that I used in my IV that work well. For my SIX conversion I installed the TC on the header as close to the head port as possible on #3 cylinder.
Just wondering what range of temp should I be looking for. I can idle at 350 and jump to 500 very quickly if I hold the rpms at 2500
Thoughts?
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 09-28-2005, 02:11 PM
Acox914's Avatar
Send a message via AIM to Acox914
CHT or EGT???
cht = cylinder head temp. UNDER YOUR SPAKPLUG
EGT - PROBE in the HEADER that tells you EXHAUST GAS TEMP
-Aaron
"60% of the time, it works every time"
Old 09-28-2005, 02:43 PM
Va914's Avatar
CHT.
Under the plug was not an option so I installed it high on the header. I figure it would give me some indication.
Once I get a baseline temp I will then be able to tell if something is going wrong.
914-6 in the Werks
Old 09-28-2005, 02:47 PM
Acox914's Avatar
egt's get way hotter than heads.
bad idea.... and its not setup right for CHT then is it?
its giving you a nonsense reading of the header temp...NOT head temp
-Aaron
Old 09-28-2005, 02:49 PM
Scrappy's Avatar
Exhaust gas temp is usually between 1400(rich) - 1600(lean) degrees....any correlation...don't think so.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 09-28-2005, 05:16 PM
RETIRED
Joe Bob's Avatar
CHT, oil temp and pressure are the big three......an air/fuel gauge is a better gauge for lean verus rich.
2012 ML350 3.0 Turbo Diesel
Old 09-28-2005, 07:17 PM
I know this is a little dated of a topic, but can anyone explain some specifics of a CHT, as far as where the sender would mount (need to drill into the head, or does it surface mount?). I am talking about something aftermarket for a gauge, not the CHT for the computer.
Grant
1997 Boxster 2.5L
1975 911S Project
Old 10-10-2005, 09:11 PM
Acox914's Avatar
most CHT's have a thermocouple ring that goes UNDER a sparkplug. this gives a very accurate reading.
-Aaron
Old 10-10-2005, 09:13 PM
