What's the trick...
What's the method for changing the rear trunk rollers to metal. Is there an easy way to relieve the pressure from the spring/roller connection?
X<- You're born here... You die here ->X
Kick maximum ass in between!
http://4porsche914.homestead.com/index.html
Old 01-21-2001, 08:22 PM
racejoe's Avatar
I made a special tool by taking a craftsman breaker bar and cutting a slot in the side of the hole for hanging it on a hook. You then put the spring though the slot you cut in to the hole, and use it as a lever to bend the spring around. Works great.
Old 01-22-2001, 05:20 AM
Check out: http://www.pelicanparts.com/techarticles/914_cooley/914_cooley_trunk_spring.htm
Old 01-22-2001, 10:44 AM
mejulihn's Avatar
I used a nut driver (looks like a screwdriver with a 1/4" socket on the end). Slip the socket over the end of the trunk spring and use the handle as a lever to take tension off the roller. Put some lithium grease on the rod that the roller rotates on and then install the new metal roller. Using a helper makes for a safer procedure.
Old 01-22-2001, 05:28 PM
